Malfunction Indicator Light
Old Aug 6, 2002 | 05:12 PM
fso_BamBam's Avatar
New User
Default Malfunction Indicator Light
I was out on the track today, great day for the first couple of hours, then at the beginning of hour 3, after a couple of laps, this light came on. I saw the exact moment, and in fact, it happened as I was shifting from 3-4, there was a brief hesitation, and then the light was on. This is the light to the lower left of the oil pressure light.
The description on the manual says this indicates some sort of an emission problem with the engine, and the dealer should see it right away. I am having it checked tomorrow, my question to the board is, has this happened to anyone else? I wish there was more detailed info on what might be wrong. I drove back home after that, and the 30 minute drive was nice, smooth, as if nothing has happened. No engine, tranny, or gearbox problems to note. I hope this is nothing serious. So far, with 30+ track days, the car has held up like a rock.
Old Aug 6, 2002 | 05:18 PM
uNF$@#!'s Avatar
Default Re: Malfunction Indicator Light (fso_BamBam)
youre refering to the check engine light?
if thats the case, pull out a helms manual and check the code by jumping the service connector.
[Modified by Soup ****, 9:18 PM 8/6/2002]
Old Aug 6, 2002 | 05:22 PM
yoshi234's Avatar
I shoot brides
did ya tighten the gas cap to at least 3 clicks?
Old Aug 6, 2002 | 05:23 PM
STOLEN - ITR 98-0652's Avatar
Get yourself one of these and these.
And check out this... if you get the code, someone here can clue you in.
Old Aug 6, 2002 | 05:44 PM
jond's Avatar
Yep, happened to me.
Ended up being a few thousand dollars of engine work.
Thank god its under waranty
Old Aug 7, 2002 | 09:30 AM
fso_BamBam's Avatar
New User
Default Re: Malfunction Indicator Light (yoshi234)
Yeah, clearly that wasn't the problem. I also took three separate "driving trips" for the light to go away, but it's still there. We'll see today what happens.
Old Aug 7, 2002 | 09:31 AM
Reid's Avatar
Global Moderator
Which code is it?
Old Aug 8, 2002 | 11:21 AM
fso_BamBam's Avatar
New User
Whew, it was only that the oil level was too low and the dealership topped it off and I am set to go. Why would the check engine light come on if the oil level is low? That'll teach me to check my oil very regularly from now on.
Mitch Rosner
Dec 27, 2011 09:12 AM
marinersfaninmd
Acura TSX
Jun 15, 2009 07:24 PM
YaMaJeSty
Honda Motorcycles
Feb 9, 2008 12:47 PM
The1Ash10
Dec 18, 2005 10:46 AM
francfurter
Dec 29, 2004 08:47 PM
