Low Compression
Old Aug 18, 2003 | 08:21 AM
Hybrid 350GT's Avatar
Default Low Compression
What would cause a motor to loose compression so bad? Compressions are 26 25 25 50. What would be the causes, and is it fixable.
Old Aug 18, 2003 | 08:37 AM
RaVAGE00's Avatar
New User
Default Re: Low Compression (DOSPOWND)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOSPOWND &raquo;</TD></TR><TR><TD CLASS="quote">What would cause a motor to loose compression so bad? Compressions are 26 25 25 50. What would be the causes, and is it fixable.</TD></TR></TABLE>
Those compression numbers are waaaaaaaaaaaaaay tooo low....
Old Aug 18, 2003 | 08:38 AM
Rhetoric's Avatar
Do a leak down test to further determine what it might be. Those are pretty low numbers, it could be a few things. Do the leak down first.
Old Aug 18, 2003 | 08:43 AM
RaVAGE00's Avatar
New User
Default Re: Low Compression (typeR0059)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeR0059 &raquo;</TD></TR><TR><TD CLASS="quote">hey, he beat my record!!!
mine is 180 130 120 120 as tested by honda.
u get the crown now </TD></TR></TABLE>
Did Honda do something about those numbers.... was the car under warranty?
Old Aug 18, 2003 | 09:19 AM
Default Re: Low Compression (RaVAGE00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaVAGE00 &raquo;</TD></TR><TR><TD CLASS="quote">
Did Honda do something about those numbers.... was the car under warranty?</TD></TR></TABLE>
Its not my R motor, its a JDM B16. So obviously its not under warranty. The motor was running fine, then my friend parked it for about 2 months, then tried to start it and couldn't. Thats when the comp test was done.
Old Aug 18, 2003 | 10:54 AM
v00tecsi's Avatar
I would say to re-do the test with a new device!!! Those numbers are not right at all for that motor!!! I have a feeling that maybe it was due to a faulty Compression tester.
SilverPanda
Oct 9, 2007 10:25 PM
dbiker207
Nov 26, 2006 07:10 AM
Mr.OB*GYN_Rhett
Aug 17, 2006 10:54 PM
boosted k20
Apr 21, 2005 04:55 PM
DOHCarp
Sep 11, 2003 07:10 PM
