Largest bore....
Old Feb 1, 2003 | 03:52 PM
PrecisionH23a's Avatar
Default Largest bore....
What's the largest bore you can go with on a c5 or c1 without having cooling issues? Let's say the block is darton sleeved...
Old Feb 1, 2003 | 03:58 PM
Hooch'n's Avatar
Default Re: Largest bore.... (GudeH23a)
u still at school bro?
Old Feb 1, 2003 | 04:21 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
I think you can go all the way to 87mm but that has to be pushing it.
Old Feb 1, 2003 | 04:40 PM
nfn15037's Avatar
Default Re: Largest bore.... (ActiveAero)
I think the biggest problem at 87mm is headgasket sealing issues.
Old Feb 1, 2003 | 06:11 PM
b19coupe's Avatar
Is there any cylinder wall left between cylinders at 87mm? That has to be really pushing cylinder to cylinder spacing. I would not go bigger than 85mm unless I had money to burn.
Old Feb 1, 2003 | 06:16 PM
MK Ultra's Avatar
Eventually you're going to run into diminishing returns due to airflow limitations. Keep in mind that the head was originally designed for a 1600 cc engine.
Old Feb 4, 2003 | 01:18 PM
Default Re: Largest bore.... (MK Ultra)
so with a darton sleeved block no more then 85mm?
Old Feb 4, 2003 | 01:25 PM
MiraiZ's Avatar
I was told 84mm for a safe setup on a c5
Old Feb 4, 2003 | 03:30 PM
Default Re: Largest bore.... (MiraiZ)
and a c1?
Old Feb 4, 2003 | 03:33 PM
baonest1's Avatar
on my b18b.. i got 84mm sleeved.
MikeD21
25
Mar 25, 2016 03:53 PM
guy_from_nerk
Jul 28, 2013 12:25 PM
crxguy406
10
Mar 7, 2013 05:42 AM
Blammo
Aug 30, 2007 08:11 AM
done
Aug 11, 2004 12:07 AM
