HELP: CEL Code 72: Misfire
Old Oct 28, 2004 | 06:36 PM
propulsion1's Avatar
Default HELP: CEL Code 72: Misfire
Hi. My stock 2000's CEL light just came on, showed CODE 72. I checked and this is what it means,
Cylinder 2 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
I did a search and found out that this may be due to plugs, wires, distributor , and bent valves (SCARY!!!). The car idles fine, no hesitation under acceleration. PLEASE let me know what to check first-
Plugs? Wires? Distributor? If I replace these parts, do I need to reset the ecu, and then drive around to see if the CEL comes back on? Or does teh CEL goes away on its own after i replace these parts
I was due for my 60k service (59k now), but I know the dealer will rip me a new one to diagnose the problem. Pls advice.
Thank you.
Old Oct 28, 2004 | 06:39 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: HELP: CEL Code 72: Misfire (propulsion1)
2nd cylinder misfire is correct. You misshift at all? probably a bent valve in there. Do a compression test
Old Oct 28, 2004 | 07:52 PM
Default Re: HELP: CEL Code 72: Misfire (People_Mover)
I may have redlined it several times lately, but i did not mis-shift.
What should I check first aside from a comp test.?
Old Oct 28, 2004 | 09:42 PM
IN VTEC's Avatar
Reset the ECU to see if it's a random code. Make note of any recurring pattern of conditions if it comes on again.
Flip flop the #2 and another injector to see if the misfire moves.
Old Oct 28, 2004 | 11:04 PM
Jmm0056's Avatar
Default Re: HELP: CEL Code 72: Misfire (IN VTEC)
well definately check the cheap things first, try changing your plugs
Old Oct 29, 2004 | 03:24 PM
Default Re: HELP: CEL Code 72: Misfire (Jmm0056)
Thanks for the reply. I will do the plugs tmrw. Do I have to reset the ecu after changing plugs or will the CEL light turn off by itself if that is the problem?
gsr96cx
Dec 26, 2009 09:41 AM
AntonioH
Aug 1, 2005 09:52 AM
seifer
Apr 22, 2005 04:46 PM
1hotintegra
Jun 11, 2003 02:07 PM
