J's Intake Install Question
Old Aug 12, 2004 | 03:31 PM
v t e c 2 3's Avatar
Default J's Intake Install Question
hey guys,
i jus installed my j's racing intake into my itr.. did ne one else run into any fitment issues?? it fits in there but it kind of sits high and touches the hood when i close it.. it also hits my strut bar... is there anything i can do to make it fit better? post ne pix if you guys have them.. thanx for the help!
Old Aug 12, 2004 | 03:38 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
I had fitment problems too. I put a pad between it and the strut bar. seems to be ok now.
Old Aug 12, 2004 | 03:39 PM
.RJ's Avatar
.RJ
Default Re: (Rguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rguy &raquo;</TD></TR><TR><TD CLASS="quote">I put a maxi-pad between it and the strut bar</TD></TR></TABLE>
Damn.
Rguy's Avatar
25 Year Member
Community Builder
Default Re: (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
Damn.</TD></TR></TABLE>
Your mother doesnt need them anymore.
Old Aug 12, 2004 | 03:41 PM
Default Re: (Rguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rguy &raquo;</TD></TR><TR><TD CLASS="quote">I had fitment problems too. I put a pad between it and the strut bar. seems to be ok now.</TD></TR></TABLE>
no problems with the hood hitting the filter??? did u use the bracket that came in the box?? if so, where'd u mount it??
Old Aug 12, 2004 | 03:42 PM
Rguy's Avatar
25 Year Member
Community Builder
Default Re: (v t e c 2 3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v t e c 2 3 &raquo;</TD></TR><TR><TD CLASS="quote">
no problems with the hood hitting the filter??? did u use the bracket that came in the box?? if so, where'd u mount it??</TD></TR></TABLE>
I got it used from a member. Bracket not included.
Old Aug 12, 2004 | 03:44 PM
B2FiNiTY's Avatar
You have to rotate the filter downwards and it will clear the hood. I had no clue where to put the bracket so I never used it.
Old Aug 12, 2004 | 03:51 PM
Default Re: (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">You have to rotate the filter downwards and it will clear the hood. I had no clue where to put the bracket so I never used it. </TD></TR></TABLE>
i'll try doing that.. does ur hit the strut bar?? my intake seems to hit the strut bar pretty nicely..
Old Aug 12, 2004 | 04:42 PM
Jackson's Avatar
Default Re: J's Intake Install Question (v t e c 2 3)
So that was you that came into the shop. I would recommend using some sort of foam tape to protect the intake from the strut bar.
Old Aug 12, 2004 | 05:04 PM
emotionisdead's Avatar
Very Emergency!!
Default Re: J's Intake Install Question (Jackson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jackson &raquo;</TD></TR><TR><TD CLASS="quote"> I would recommend using some sort of foam tape to protect the intake from the strut bar.</TD></TR></TABLE>
this sounds like a pretty good idea to me
Old Aug 12, 2004 | 07:34 PM
SLCTyper's Avatar
Take the bracket and get two sets of channel locks to bend it so it looks like this: "[" instead of an "L" shape. I then took the two ends of the now "C" shaped bracket and bent them slightly in oposite directions. I bolted the bracket into one of the stock air box holes (one closest to you and to the right when looking at the engine bay), and pushed the filter down just enough to slip the other end of the bracket between the filter and the hose clamp that holds the filter on the intake pipe. The bracket pulls the intake down far enough that there is about a 1/8-1/16" gap between the strut bar and intake. May not make any sense, but if you are interested, I'll take some pics when I get the R back (hopefully tomorrow ).
Old Aug 12, 2004 | 08:38 PM
white rocket's Avatar
Default Re: J's Intake Install Question (SLCTyper)
No fitiment problems with mine. Just one of the spark plug wire ends connected to the distributor rubs a little on the carbon fibre piece. No brackets needed, just hooked up to TB and that's it.
Old Aug 12, 2004 | 11:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLCTyper &raquo;</TD></TR><TR><TD CLASS="quote">
Take the bracket and get two sets of channel locks to bend it so it looks like this: "[" instead of an "L" shape. I then took the two ends of the now "C" shaped bracket and bent them slightly in oposite directions. I bolted the bracket into one of the stock air box holes (one closest to you and to the right when looking at the engine bay), and pushed the filter down just enough to slip the other end of the bracket between the filter and the hose clamp that holds the filter on the intake pipe. The bracket pulls the intake down far enough that there is about a 1/8-1/16" gap between the strut bar and intake. May not make any sense, but if you are interested, I'll take some pics when I get the R back (hopefully tomorrow ).</TD></TR></TABLE>
some pix would be very helpful.. thanx for the help!
Old Aug 13, 2004 | 07:48 AM
HondaRcB's Avatar
I didn't use the bracket. I just bent my A/C lines apart a bit and it fit great. No rubbing what so ever. Best pic I have at the moment.
Old Aug 13, 2004 | 09:27 AM
pwrdbyhonda's Avatar
mine when in perfect
Old Aug 13, 2004 | 10:23 AM
Default Re: (pwrdbyhonda)
i'm going to take it out and reinstall it.. maybe it'll fit better.. but i think i'm goin to need to pad the strut bar area...
MADBADGER
Honda S2000
17
Dec 31, 2007 12:35 AM
scottso990
Nov 15, 2007 05:49 PM
PrOjEkT-CiViC
May 18, 2007 10:13 AM
ILuvMyJdmDc4
May 13, 2007 12:21 PM
jdmCivic925
Nov 21, 2003 06:16 AM
