JDM type R block code question
Old Sep 7, 2003 | 08:27 PM
Sohc Driver's Avatar
Default JDM type R block code question
I wasn't completely sure on this issue..but isn't the JDM Type R block code B18C...which is also the same as the JDM GSR? I've also seen the code b18CR as well...can someone help distinguish the motors with their codes?
Khoi
Old Sep 7, 2003 | 08:49 PM
MiraiZ's Avatar
Default Re: JDM type R block code question (Sohc Driver)
JDM Type R and GSR are both B18C the only way to distguish the two is by the head, tranny, intake, and exhaust.
Old Sep 7, 2003 | 08:52 PM
all stock's Avatar
Default Re: JDM type R block code question (MiraiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">JDM Type R and GSR are both B18C the only way to distguish the two is by the head, tranny, intake, and exhaust.</TD></TR></TABLE>
and the bling bling valve cover.
Old Sep 8, 2003 | 06:17 AM
Default Re: JDM type R block code question (all stock)
so where does the b18cR come from?
Khoi
Old Sep 8, 2003 | 07:02 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
never seen a block that said b18cr. might be a custom job. I don't believe any honda motors came that way.
Old Sep 8, 2003 | 07:53 AM
Default Re: JDM type R block code question (Apex i ITR)
I've seen a few..but i am assuming that the b18CR was only for european or austrailian Rs.....can anyone shed some more light on this?
Khoi
Old Sep 8, 2003 | 10:55 AM
B2FiNiTY's Avatar
No such motor came with the stamp b18cr - that is just slang.
Old Sep 10, 2003 | 07:57 PM
Turbo(less)DB8's Avatar
Default Re: JDM type R block code question (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">No such motor came with the stamp b18cr - that is just slang.</TD></TR></TABLE>
here here
Old Sep 10, 2003 | 08:00 PM
jonas's Avatar
i agree with B2.. i've never seen a block with a "B18CR" on it.
when people on honda-tech or anywhere else say "B18CR".. they are just refering to the JDM ITR motor since a simple "B18C" is not as specific.
Old Sep 10, 2003 | 08:30 PM
92TypeR's Avatar
FSAE
Default Re: (jonas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonas &raquo;</TD></TR><TR><TD CLASS="quote">when people on honda-tech or anywhere else say "B18CR".. they are just refering to the JDM ITR motor since a simple "B18C" is not as specific.</TD></TR></TABLE>
Exactly. B18C-R is just a way to verbally distinguish between the ITR and SiVtec/SiR-G.
Pistons and crank can tell you what motor it is if you just have the block. But require a little effort.
Old Sep 10, 2003 | 08:41 PM
MiraiZ's Avatar
Default Re: (92TypeR)
yup...there are distinctions between chassis though.
jdmh22bubble
Jan 10, 2010 02:34 PM
smileycvc
May 17, 2008 12:39 PM
B18Redline
Dec 20, 2004 12:37 AM
eknine
May 22, 2003 05:47 AM
red civic standard
Dec 12, 2002 06:23 PM
