jdm headlight hid bulb replacement...
Old Nov 3, 2007 | 04:16 PM
NorthernXposure's Avatar
Default jdm headlight hid bulb replacement...
im assuming that the headlight must be removed to access the bulb? along with removing the ballast.. any info would be greatly appreciated.. thnx in adnvance
Old Nov 4, 2007 | 04:23 PM
Default Re: jdm headlight hid bulb replacement... (NorthernXposure)
anybody?
Old Nov 4, 2007 | 04:24 PM
JjuuN R's Avatar
USDMFRONT4LYFE!!
How you been buddy? Besides one of your bulbs going out?
Old Nov 4, 2007 | 09:18 PM
dcRay's Avatar
Yes, you have to remove the entire headlight to change out the bulb because there are screws on the bottom holding the ballast cover.
Old Nov 5, 2007 | 09:56 AM
Rishiras's Avatar
Is this OEM HID Honda bulb interchangeable with higher Kelvin bulbs??
I dont like the OEM HID its too yellow around 4300K i think oem honda is.
any suggestions which bulb to use on the oem hid from honda ?
I like the 6000K.
Old Nov 5, 2007 | 10:14 AM
totsie7944's Avatar
Default Re: jdm headlight hid bulb replacement... (Rishiras)
4300k is the whitest and brightest of HID's....
Old Nov 5, 2007 | 11:28 AM
Casey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rishiras &raquo;</TD></TR><TR><TD CLASS="quote">Is this OEM HID Honda bulb interchangeable with higher Kelvin bulbs??
I like the 6000K.
they are 4300k but mine are nowhere near yellow
Old Nov 7, 2007 | 03:19 AM
Rishiras's Avatar
Default Re: jdm headlight hid bulb replacement... (Casey)
well compared to a 6000K it is too white and if housing is bit old it has a light effect of yellowness.
Its ok, but i wanted to know if it can be changed from 4300k to 5000k or something near, I guess i need NEw HID headlamps, which is expensive oem honda.
Old Dec 9, 2007 | 06:22 PM
JDM_ITR's Avatar
what is the actual size of the bulb for the jdm hid bulb?
Old Dec 9, 2007 | 08:50 PM
ViSiONxBoY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NorthernXposure &raquo;</TD></TR><TR><TD CLASS="quote">im assuming that the headlight must be removed to access the bulb? along with removing the ballast.. any info would be greatly appreciated.. thnx in adnvance</TD></TR></TABLE>
You would have to remove the entire ballast from the headlight and remove the bulb, the bulb is a Phillips D2S bulb. I suggest you go buy the Phillips D2S replacement bulb on eBay as it's only about 60 bucks per bulb. Where as at Honda/Acura dealerships they run for about $80 and that's at employee price and it's the same Phillips bulb but in a small Honda box. I saw list price for one was $120
TurbothisLS
Sep 30, 2016 08:42 AM
2n-chilli
Dec 9, 2013 08:31 PM
Accord1234
Lighting
10
Jun 7, 2008 07:28 AM
invisible
Nov 29, 2006 07:52 PM
JforJonathan
Mar 13, 2004 01:10 PM
