Js there computer skunk 2 ??
Old Dec 26, 2004 | 07:24 AM
krystianitr's Avatar
Default Js there computer skunk 2 ??
Hello
I bought cam shaft skunk 2 stage 2 and Skunk2 Valve Springs & Titanium Retainers Type R pistons CR 12.2:1 and RC Engineering Injectors 310cc
I have question , because I need computer , which will cooperate with this set and change from obd 2 to obd1.
Is there computer skunk 2 to modifiction. I have in my ITR ?
If yes , guve me a link where I can see it , I'm not from the USA.
Help me guys
Old Dec 26, 2004 | 08:28 AM
99 TYPE R's Avatar
im runnin obd2 to obd1 skunk 2 setup in my car
Old Dec 26, 2004 | 08:31 AM
Chris F's Avatar
Default Re: Js there computer skunk 2 ?? (krystianitr)
Are you just looking for OBD2/OBD1 conversion harness, or for a computer to tune your setup? Yeah, Skunk 2 and others have a conversion harness.
For the computer, something out-of-the-box won't be tuned for your setup. You want something that can allow someone to tune fuel/timing/VTEC on your car like Hondata.
It might be difficult to find a Hondata tuner in your area-- they need a EPROM burner, and some experience on Hondata to tune your car.
Hondata S100 computer (S200 has datalogging and some other stuff)
http://www.hondata.com/s100.html
OBD1/OBD2 conversion harness
http://www.hondata.com/adapters.html
Last three dyno charts are of ITR's (Naturally aspirated)
http://www.hondata.com/dynocharts.html
Old Dec 26, 2004 | 08:56 AM
Default Re: Js there computer skunk 2 ?? (Chris F)
I don't looking OBD2/OBD1 conversion harness but I need ecu(computer)to tune my setup
Is there ecu which work's skunk 2 for cam shaft stage 1
Is there different for stage 2
Old Dec 26, 2004 | 09:00 AM
Chris F's Avatar
Hondata works for everything, if you tune it. I'm not sure if Kenji or Spoon or Skunk ECU's would work well or not, but Hondata will get you more power because it's tuneable.
Old Dec 26, 2004 | 09:11 AM
chris F
THX
but you tell me Is there ecu skunk 2 for cam shaft stage 2 and RC Engineering Injectors 310cc
I need only this ecu!?!
Old Dec 26, 2004 | 10:30 AM
Chris F's Avatar
I don't know of any ECU that assumes you have 310cc injectors and stage 2 cams. If you're going to start playing with injector sizes you really need stand alone tuning.
Search!
http://www.maryjanesgarden.com/skunk_2.php
[edit, more useful link https://honda-tech.com/zerothread?id=504196 ]
Old Dec 27, 2004 | 12:58 PM
white rocket's Avatar
I believe what Chris F is trying to say is that there isn't an ECU that is built specifically for your set-up. In turn you will have to get a Hondata*shameless plug* and either tune it yourself or get a tuner to do it. There may be some basemaps kickin' around that are 'similair' to your set-up.
<----who loves gettin' his $0.02 in.
Old Dec 27, 2004 | 01:12 PM
JDM Factor's Avatar
buy a p28 and run the skunk setup
turbodsmpower
Aug 18, 2003 01:49 PM
hYpE-R-29
Jun 29, 2002 03:24 PM
GSRwBOOST
Apr 9, 2002 01:10 PM
Pinhead
Mar 13, 2002 10:00 PM
neumonik
Dec 7, 2001 08:44 AM
