Js Racing B18C Engine?
Old Jan 21, 2005 | 06:31 AM
SleeperR's Avatar
Default Js Racing B18C Engine?
Does anyone know about the Js Racing B18C engine? I know they offer a crate B18C long block. All engines has been balanced & blueprinted. All engines are equipped with J's Racing valve cover, oil pump, oil pan and oil filler cap. Does anyone know the power output??? Compression? Just curious.. Thanks
Tristan
00-0503
Old Jan 21, 2005 | 07:21 AM
mafay2's Avatar
New User
Default Re: Js Racing B18C Engine? (SleeperR)
I don't think it come with the Js oil cap. They also used oversize JDM ITR piston and stock head gasket, so compression should be around 11.1:1. It also have some minor headwork done too. Power output will be very similar to the stock B18C Type R, but it should run smoother because it is balanced and blueprinted.
Old Jan 21, 2005 | 09:02 AM
B2FiNiTY's Avatar
Default Re: Js Racing B18C Engine? (mafay2)
I want one of those valve covers
Old Jan 21, 2005 | 10:26 AM
Curt941's Avatar
Default Re: Js Racing B18C Engine? (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">I want one of those valve covers </TD></TR></TABLE>
Give me your valve cover, $50 and some turquoise paint and i'll make you a C's Racing Valve cover...works just as good.
Old Jan 21, 2005 | 10:36 AM
EEK's Avatar
EEK
Default Re: Js Racing B18C Engine? (Curt941)
hahah too funny
Old Jan 21, 2005 | 11:11 AM
mafay2's Avatar
New User
I have one and the quality of the paint is not too good. After 1 yr, there are bubble on the paint and some of the paint started to chip off. May be they forgot to use high temperautre paint.
Old Jan 21, 2005 | 11:22 AM
DC2IntegraTypeR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mafay2 &raquo;</TD></TR><TR><TD CLASS="quote">
I have one and the quality of the paint is not too good. After 1 yr, there are bubble on the paint and some of the paint started to chip off. May be they forgot to use high temperautre paint. </TD></TR></TABLE>
Sounds like the Spoon valve cover (Which often come defective as in it's chipped or the paint is bubbling). My friend had to pick the best 1 out of 5 when he decided to buy one.
Aside from that I like the color of the J's racing valve cover. It reminds me of the ocean.
You would think that high-end JDM stuff is high quality. Anyone with experiences with Mugen valve covers?
Also, any significant difference between the balancing and blueprinting between Spoon B18C and J's Racing B18C crate motors aside from the oil pump, pan, etc.
Old Jan 21, 2005 | 12:13 PM
RobbieG35's Avatar
12 Years Strong
Sounds like how my Spoon was I will stick with my ARRR
Old Jan 21, 2005 | 05:56 PM
mafay2's Avatar
New User
Default Re: Js Racing B18C Engine? (THEINTEGRATION)
Beside balanced and blueprinted, the Spoon engine came with their headgasket, oil pump, and stock oil pan.
J's Racing engine came with the following (Email I got from J's Racing)
--- Cylinder head ---
Upper surface correction
Valve polishing
Port correction
--- Cylinder Block ---
Boring & Horning*(use O/S Piston)
Metal measurement adjusting
Valve clearance & Valve timing adjusting
Valve seat cut
Valve rub adjusting
J'S RACING Oil pan (baffle processing)
J'S RACING Head cover
J'S RACING FILLER CAP
--- NEW PARTS ---
THERMOSTAT
OIL PUMP
WATER PUMP
TIMING BELT
CRANK PULLEY
TENSIONER
I think the Spoon engine is a brand new engine, but the J's Racing is a rebuild engine (that why they used O/S pistons).
I have the Spoon engine before and the J's Racing engine now, they are very similar in power. J's Racing one may be a bit stronger. However, both engine tend to start burning oil after around 8 - 10k km. My J's Racing engine is burning around 1L of oil every 2500km!!
Old Jan 21, 2005 | 06:13 PM
GUILOTINE's Avatar
Kill Gil
me too I would even trade my mint Spoon for one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEINTEGRATION &raquo;</TD></TR><TR><TD CLASS="quote">
Also, any significant difference between the balancing and blueprinting between Spoon B18C and J's Racing B18C crate motors aside from the oil pump, pan, etc.</TD></TR></TABLE>
weird, My spoon is in Mint condition and my fried used it for like 6 month before I bought it from him, The I used it for like another 6 and my EG was a daily. No boubles or anything? You sure you friends was authentic? BTW the mUgen one is has no issues either and My bro has daily drove it for like 2 years
<FONT SIZE="5">mine</FONT>
<FONT SIZE="5">my bro's</FONT>
Old Jan 21, 2005 | 06:20 PM
MooFX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mafay2 &raquo;</TD></TR><TR><TD CLASS="quote">Beside balanced and blueprinted, the Spoon engine came with their headgasket, oil pump, and stock oil pan.
Valve polishing
Port correction
Valve seat cut
Valve rub adjusting
--- NEW PARTS ---
THERMOSTAT
OIL PUMP
WATER PUMP
TIMING BELT
CRANK PULLEY
TENSIONER
Now, did you run both motors in properly?
Old Jan 21, 2005 | 06:21 PM
Default Re: Js Racing B18C Engine? (gIl dA FunKy HomOsaPieN!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gIl dA FunKy HomOsaPieN! &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, came in authentic Spoon packaging too
Old Jan 21, 2005 | 06:22 PM
mafay2's Avatar
New User
Default Re: Js Racing B18C Engine? (MooFX)
Of course I did.
Old Jan 21, 2005 | 07:35 PM
ITRbroham's Avatar
shit post warrior
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mafay2 &raquo;</TD></TR><TR><TD CLASS="quote">Of course I did. </TD></TR></TABLE>
Something sounds fishy, indeed.
Old Jan 21, 2005 | 08:23 PM
mafay2's Avatar
New User
Default Re: Js Racing B18C Engine? (ITRbroham)
Well, I kinda disappointed at the burning oil problem too, but I guess I am not the only one that is burning oil with a Type R engine. But the J's Racing engine did run very smooth and dyno showed peak power at 8150RPM with stock cams.
delsol-101
Sep 4, 2014 09:50 AM
cslegacy
Mar 23, 2009 05:51 AM
project.mu
Oct 2, 2005 05:02 PM
ericsson
Mar 25, 2004 09:45 AM
cleanEG
Feb 20, 2003 03:30 PM
