ITR Problem Need help!
Old Nov 7, 2010 | 01:49 PM
IBriaIN's Avatar
Default ITR Problem Need help!
I VTECed to pass a slow car on the free way yesterday (7600 rpm), and by the time I got to the exit my car started to sound like a hot rod and struggle, and as I press on the gas to drive, my car starts to sound like a subaru. I asked one of my friends to pin point the problem, and he guesses that the car is running on 3 cylinders. Does anyone have any other ideas what the problem might be?
Kind Regards,
Brian
Old Nov 7, 2010 | 03:23 PM
1998GsRIntegra's Avatar
Default Re: ITR Problem Need help!
Check your plugs see what they look like. Do a compression test so you know you didn't lose anything important when vtec kicked in yo! If your plugs look fine and it has good even compression across the board then look to the plugs wires and distributor.
Old Nov 7, 2010 | 03:29 PM
BlueIntegraBoy's Avatar
Cracked insulator on one of your spark plugs
Old Nov 7, 2010 | 05:16 PM
That was my thought but I didn't really want to say something that narrow. Glad my thinking was correct.
Old Nov 7, 2010 | 05:31 PM
Happened to me and my friend
Old Nov 7, 2010 | 06:32 PM
racebum's Avatar
agree with your friend. it's running on 3 cylinders. shattered exhaust valves from excessive oil burning are the #1 cause of this
Old Nov 8, 2010 | 05:24 PM
IBriaIN's Avatar
Yea, I had my friend stop by and check it out. the plugs are working and there is gas being put out, and still the same problem. What did you guys end up doing? Engine rebuild?
btw BlueIntegraBoy, do you still do the rear strut bar covers?
Kind Regards,
Brian
Old Nov 8, 2010 | 05:33 PM
Won't be able to do it until the end of December
Old Nov 9, 2010 | 04:33 AM
per4mance's Avatar
burnt valve, do a compression check
Old Nov 11, 2010 | 02:54 PM
IBriaIN's Avatar
I'll chime in DEC BlueIntegraBoy
First I need to get the car towed to my friends shop, but they're saying its gonna cost about $750 to take out the engine and disassembling it. On top of that, since cylinder 4 is out, and the spark plug tip is broken they're thinking that the cylinder wall is damaged. So the motor is blown, and recommend me to get a new type-r engine thats gonna run be about $4,000. How much does an engine rebuild cost? I'm willing to spend about $2,500. Please help!
Kind Regards,
Brian
Old Nov 11, 2010 | 03:03 PM
94rs-turbo's Avatar
k-swap????
Old Nov 11, 2010 | 06:35 PM
Kind Regards,
Brian
If you are mechanically inclined you can diy it, but if you have never even taken a head off of a motor, I wouldnt even try to mess with it yourself. The best way to see whats f***ed up is to use a bore scope. If its a good one not only will you be able to tell if the cylinder wall was damaged, it will also turn up so you can look at the valves.
Old Nov 11, 2010 | 06:48 PM
dimo92's Avatar
i bent all 8 exhaust valves on my gsr. just take off the head and do a leak test to see what valves are bent. the hardest part for me was making sure i set the timing up correct, didnt want to do another rebuild lol also if you are doing it yourself make sure you know all the things like torching down the head, etc. talk to your friends, reasearch online and you might just be able to get away with a couple hundred bucks in parts.
Old Nov 11, 2010 | 08:41 PM
IBriaIN's Avatar
I'm currently in school right now, and don't have time to rebuild my own engine. I'm planning to drop it off at a honda specialist. How much are the going rates for engine rebuilds for a b18c5 motor? (so i don't get ripped off) I'm planning to use Hondapartsunlimited.com for parts, unless someone can direct me to a cheaper place.
Thanks for the info so far guys!
Brian
Old Nov 11, 2010 | 08:49 PM
racebum's Avatar
you'll spend more than you would if you sell that engine as is and just buy a jdm itr engine for $2500. without you doing the labor it's going to cost you more than 1500 for a toatal rebuild
Old Dec 2, 2010 | 04:55 PM
IBriaIN's Avatar
Guess what? Diagnosis was right...cracked valve!
http://sphotos.ak.fbcdn.net/hphotos-..._5710862_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._7044557_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._6265775_n.jpg
Old Dec 2, 2010 | 06:45 PM
So was the cylinder wall damaged? A piece that small could have been blown out the exhaust before it was able to damage.
MyEfSi2Slow
Mar 9, 2008 06:42 PM
CARflyGUY
May 30, 2007 07:20 AM
coronadrinker
Feb 28, 2007 04:54 PM
abmerop18
Mar 15, 2006 04:51 PM
hondacivic_si
10
Jul 16, 2004 08:31 AM
