Idle problem
Old Oct 12, 2003 | 04:53 PM
gsrcivict's Avatar
Default idle problem on new itr
I just bought a 2000 py itr that is stock. whenever I come to a light or something and the cars at a idle it kinda stutters like its missing or something. any idea what this could be? I know its kinda a vague description but I really wish there was a way I could let you guys hear it. runs fine and all but just doesnt feel like its potential. engine kinda shakes a lil also. feels kinda slugish untill like 6000 rpms. just thought maybe one of you fellow itr owners with some experience could help me out. thanx for your help!
Gabe
Old Oct 12, 2003 | 05:01 PM
ZygSpeed's Avatar
Default Re: idle problem on new itr (gsrcivict)
I'd imagine a nice little tune-up with a new rotor/cap/plugs and maybe even fresh wires wouldn't be a bad idea.
Depending on the miles it might be time for a timing belt as well, though not unless you've got more than 60K on the odometer.
Old Oct 12, 2003 | 05:03 PM
uNF$@#!'s Avatar
Default Re: idle problem on new itr (zygspeed)
engine mount?
if you know absolutely nothing about the car, go take it to the stealership
Old Oct 12, 2003 | 05:05 PM
hYpE-R-29's Avatar
whats the mileage on the R?, what kind of gas u put?, oil?..basically do a tune up
Old Oct 12, 2003 | 05:11 PM
gsrcivict's Avatar
Default Re: idle problem on new itr (hYpE-R-29)
I put 93 octane and yea I know its prolley due for a tune up. I got some motor flush and some mobile 1 synthetic Im gonna put in it tomorrow. the guy I bought it from didnt do anything to it and really didnt have it too long. Its got around 67,000 miles. It also throws a check engine codes every once in a while. its thrown a 45, and a 10 bit I reset it and it goes away. Im gonna tune it up tomorrow and I already ran a gas treatment thingy in the last full gas tank. Just thought if maybe someone else has had this problem. I think 10 is a IAT sensor, but I know the 45 is too lean or too rich. Just dont understand why a STOCK itr would throw that code.
Old Oct 12, 2003 | 05:19 PM
ZygSpeed's Avatar
I'd say plugs, rotor and cap will help significantly.
Then, reset the computer and see if any codes come up and work on it from there.
Old Oct 12, 2003 | 05:21 PM
hYpE-R-29's Avatar
how do u check the codes again if u have a CEL light..i forgot
Old Oct 12, 2003 | 06:37 PM
gsrcivict's Avatar
I will put in some new plugs tomorrow. anyone have any suggestions on which ones to use?
Old Oct 12, 2003 | 09:52 PM
Bbasso's Avatar
"feels kinda slugish untill like 6000 rpms"
Haaaaahaaahaaa hahahaha hahaha hahah hehehe thats the funniest thing I have read on here in a very long time!!
Old Oct 12, 2003 | 09:59 PM
Spartanic's Avatar
Check all grounds for corrosion. Believe or not but they make a great differnece. Check the ground on the thermostat housing becuase that's really important also, make sure its snug.
Old Oct 12, 2003 | 10:02 PM
^jefs0ng's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hYpE-R-29 &raquo;</TD></TR><TR><TD CLASS="quote">how do u check the codes again if u have a CEL light..i forgot </TD></TR></TABLE>
Old Oct 13, 2003 | 06:57 AM
gsrcivict's Avatar
Default Re: idle problem on new itr (Bbasso)
ummmmmmmmmmmmm I dont see the joke? sorry. what you mean?
"bbasso"
Old Oct 13, 2003 | 09:07 AM
Fac3Man's Avatar
Tune up?
Code 45 is related to fuel, 10 is the IAT sensor. Before you do a tune up that you probably dont need, probe the IAT sensor. No sense in doing a "tune up" if there is no need. HTH...
What he meant was that VTECH doesnt activate until around 6K, hence the sluggish pick up. I hope thats not the "problem".
Old Oct 13, 2003 | 09:14 AM
ZygSpeed's Avatar
Default Re: idle problem on new itr (Fac3Man)
OK, fuel filter included in the "tune up"!
Old Oct 13, 2003 | 09:18 AM
Opie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">I'd say plugs, rotor and cap will help significantly.
Then, reset the computer and see if any codes come up and work on it from there. </TD></TR></TABLE>
Mine was doing the same thing, swapped out new cap plugs wires and rotor and it all now!
Old Oct 13, 2003 | 11:40 AM
gsrcivict's Avatar
ok how do you "probe" the iat sensor? that is the one on the intake manifold right? next to the trottle body?
I just put some motor flush in and changed the oil to 5w30 mobile 1, changed the plugs with the ngk pkr6g-11 ($10 a plug! DAMN). seems to run a lil better. no check engine codes yet. I just went down the road a couple of miles and got all over it and it seems a lil better. still has like a missing sound and idles a lil high. like 1000rpms. I also noticed its spitting a lil oil out where that lil black oil box is on the back of the block. by the oil filter. could that cause this problem? thanx for you guys help man ya are the greatest!
Gabe
Old Oct 13, 2003 | 11:44 AM
gsrcivict's Avatar
oh and when I pulled out the old plugs they looked a lil white? is dis guud o bad?
Old Oct 13, 2003 | 04:29 PM
gsrcivict's Avatar
Default Re: (gsrcivict)
Old Oct 13, 2003 | 04:54 PM
nugen power's Avatar
you could be only running 3 cylinders..... get your sparkplugs checked
Old Oct 13, 2003 | 06:54 PM
greenlightauto
Guest
Posts: n/a
wait wait wait just dont throw parts at it.... find out whats wrong then fix it. compression test leak down test then check it with a scope. check for codes and then fix it. give me a call if you need help jerry sample greenlight auto repair san diego (858)569-0693 or email greenlightauto7853@sbcglobal.net
Old Oct 13, 2003 | 07:04 PM
nightrider's Avatar
check it out...
http://www.c-speedracing.com/faq/03.php
Old Oct 13, 2003 | 07:08 PM
jdmspoonitr's Avatar
Default Re: idle problem on new itr (greenlightauto)
Hmmm the idleing problem and the oil leaking from the pcv doesn't sound like it was stock. I think I would run a carfax, or try and dig up the real history of the car. Could be that you bought a car that was either nos'd or boosted, which would be a wrongful sale by the owner. Good luck
Old Oct 13, 2003 | 08:30 PM
gsrcivict's Avatar
Default Re: (nugen power)
get them checked? by whom? what you mean?
Old Oct 13, 2003 | 08:33 PM
gsrcivict's Avatar
whats the compression supposed to be? I will check it tomorrow. "check it with a scope"? dont know what that is. what if everytime it throws a code, I see what it is and then reset it and it goes away. then when it does throw a code again its a totally different code? Im like wtf?
Old Oct 13, 2003 | 08:35 PM
gsrcivict's Avatar
Default Re: idle problem on new itr (jdmspoonitr)
the guy I bought it from said he only had it for like 6 months. he was about to be a father and had to get rid of the car. I WILL call him and ask him wtf? the only thing that he knkew of that was done to the car was a clutch was added. the kid really didnt know much about cars in general just liked the itr.
