How long does the tin foil around the 02 trick work???
just like the title says how long does it work, i guess i should ask how long have you (who have this) had it... im running a T1R testpipe and ive read the only way not to throw a CEL is this or getting a sim, also is there anyother things that work??? Thanks
Re: How long does the tin foil around the 02 trick work??? (teg01type-r)
just check periodically and re-wrap heavily as needed...
it should work for 2-3 months at a time
Re: How long does the tin foil around the 02 trick work??? (BlueR)
also i dont plan on plugging it in to the testpipe, due to it not having a 02 bung... so will it still eat away the tin foil???
yes, it will still heat up and eat thru the tin foil...
hence:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR »</TD></TR><TR><TD CLASS="quote">just check periodically and re-wrap heavily as needed...
it should work for 2-3 months at a time</TD></TR></TABLE>
hence:
Re: How long does the tin foil around the 02 trick work??? (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg »</TD></TR><TR><TD CLASS="quote">PS I have Heavy Duty JDM tin foil available to avoild less frequent reapplication.</TD></TR></TABLE>
Do you have JDM sandwich bags? I want some because they make your sandwich last longer. But how do I order some of that Heavy Duty JDM tin foil for my burritos, I take them to work for LUNCH. mmmmmmmmmm LUNCH
Re: How long does the tin foil around the 02 trick work??? (gato5254)
just get a bung welded in your test pipe and put the sensor in man....save yourself trouble down the road
Re: How long does the tin foil around the 02 trick work??? (totsie7944)
you can do this trick http://www.s2ki.com/forums/ind...&st=0
i.ve done it on a few cars and it worked everytime. one car even had an electronic simulator in it that failed to work after a few hundred miles.
before the defoulers i ran the foil over the 02 wrapped in 2 sandwich bags(to keep the sensor from getting wet) for about a year.
Re: How long does the tin foil around the 02 trick work??? (DontBlink)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DontBlink »</TD></TR><TR><TD CLASS="quote">you can do this trick http://www.s2ki.com/forums/ind...&st=0
before the defoulers i ran the foil over the 02 wrapped in 2 sandwich bags(to keep the sensor from getting wet) for about a year.</TD></TR></TABLE>
Awesome Idea.
Awesome Idea.
eg_passion
10
01-28-2007 01:12 PM
