Highest Compression
Old Mar 29, 2002 | 08:59 AM
HalifaxITR's Avatar
Default Highest Compression
I've done the search but came up empty.
What is the highest compression you can run on 91 octane gasoline?
Old Mar 29, 2002 | 09:12 AM
nfn15037's Avatar
Default Re: Highest Compression (HalifaxITR)
Its all about tuning and how much ignition advance you run. Ill just say you if you want to be safe running high compression, go with a standalone like Hondata. Just my $.02
Old Mar 29, 2002 | 09:28 AM
HalifaxITR's Avatar
Default Re: Highest Compression (nfn15037)
My goal is 190 - 200 whp,
I'm getting Toda Bs, but to get more out of them I should bump up my compression. I plan to use a chipped/ re-programmed ecu.
All I can get around here is 91 octane.
Any recommendations.
Old Mar 29, 2002 | 09:33 AM
ak-s2000's Avatar
QUOTE]My goal is 190 - 200 whp,
Any recommendations.[/QUOTE]
I would say a 12:1 ratio would be safe with an reprogrammed ecu or go with a stand alone ecu computer.[
Old Mar 29, 2002 | 09:42 AM
AllMotorITR's Avatar
New User
Default Re: Highest Compression (ITR_0207)
Tuning, Tuning, Tuning! I know someone running 12.5:1 compression on 91 octane, with Hondata... And he has yet to have any problems with his motor.. and this is going on 4 months.
Old Mar 29, 2002 | 11:31 AM
GokuSSJ4's Avatar
Default Re: Highest Compression (1 FAST R)
IMO dont push it ! to run 91 with no problems the most 11.5 CR with hondata maybe 12.1 CR the most .
Old Mar 31, 2002 | 11:28 PM
t's Avatar
t
How are you planning to raise the compression ratio?
Old Apr 1, 2002 | 02:57 AM
HalifaxITR's Avatar
Default Re: Highest Compression (t)
I was planning on getting JDM ITR pistons, and hope that it will increase my compression enough to make better use of the spec Bs'
Old Apr 1, 2002 | 07:50 PM
t's Avatar
t
you will have no problems with the JDM ITR pistons and 91 octane.
Old Apr 1, 2002 | 08:05 PM
GokuSSJ4's Avatar
on a b18c the most 11.1 with thinner head gasket 11.4 . milling the head i wouldnt recommend it with spec B
you should have no problems running 91 with that CR .
Old Apr 1, 2002 | 08:31 PM
00specR's Avatar
Default Re: Highest Compression (Spoon1)
hey....where in l.a......we ran at palmdale...13.6.stock jdm itr......now with 11.4:1 CR...head work and cams we want 12's and hopefully 210whp...91 octane...we'll see
Old Apr 1, 2002 | 08:35 PM
Pinhead's Avatar
New User
Default Re: Highest Compression (00specR)
in what kinda car? HB?
Old Apr 1, 2002 | 08:54 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Highest Compression (Pinhead)
My old Mercedes ran 18:1 compression...
Old Apr 1, 2002 | 09:19 PM
00specR's Avatar
92 hb
Old Apr 1, 2002 | 09:53 PM
GokuSSJ4's Avatar
yeah that will make a difference you have a lighter car then mine
what was it cx,dx, vx, si???and also a little better improvement and im sure i could knock it down to at least 13.7 had a 2.0 60ft .. but i should go more often
Old Apr 2, 2002 | 02:34 AM
kenji's Avatar
25 Year Member
itr009,
Yeah, but your old Mercedes had a diesel engine
-kenji
freeshot350
Aug 13, 2007 08:09 PM
pumpkyn
19
Aug 17, 2006 09:24 PM
limpy
Jun 27, 2005 01:04 AM
Mad Cow Disease
May 20, 2004 11:30 AM
AL ASPIRATED
Aug 22, 2003 04:52 PM
