help with wheel spin
Old Feb 24, 2003 | 08:01 AM
typeRicer hater's Avatar
Default help with wheel spin
ok just finished my toda header install and here is my setup
aem cai
toda header
buddy club test pipe
apexi cat back n1
action 1ks with fidanza flywheel
the car feels great but the only thing is when i hit it in first(not even launching)
as soon as the car hits V-tec my tires spin like crazy. i dont know what to do and the only thing i can think of is maybe bad tires
toyo proxies z24 205/55/15 but they arent z rated, the ones right under it i think h or something.
just looking for a little help
thanks
Old Feb 24, 2003 | 08:08 AM
Misfit's Avatar
Default Re: help with wheel spin (typeRicer hater)
better tires will help.
Old Feb 24, 2003 | 08:09 AM
Austin's Avatar
Your problem lies in the proxies...I had a set once, I had issues of spinning them coming out of corners, and all the car had was an AEM intake...I really didn't like them.
Austin
Old Feb 24, 2003 | 02:05 PM
stRtypR25's Avatar
perhaps you spin your tire like crazy because of all the torque the R's come equipped with. on a serious i already told you the problem was because of your tires. damn NOOB
Old Feb 24, 2003 | 03:01 PM
Padawan's Avatar
Darth ModerVader
This isn't related to your traction problem, but you are aware that 205/55-15's are larger in diameter than the stock 195/55's, right? 205/50-15's are closer in diameter to the stock setup. Just something to consider if you are planning on purchasing new tires soon.
Old Feb 24, 2003 | 03:12 PM
nfn15037's Avatar
Default Re: help with wheel spin (Padawan)
The combination of crappy tires and a lightweight flywheel is the problem. Ditch the Toyos and get some Azenis
Old Feb 24, 2003 | 06:09 PM
DemontunedlsT's Avatar
Default Re: help with wheel spin (nfn15037)
Azenis please. If you are going to get any tire, please make it either the Toyo T1S
which is awesome for you Toyo haters and the other great tire is the BF Goodridge comp KD or KDW those wear a little worse than the toyo but they are a little stickier.
Also, do you have adjustable suspension? If you do you should lower the front a hair lower than the rear and tighten the rear struts, this will act like a wheelie bar in a sense keeping the weight of the car on the fron tires.
Old Feb 24, 2003 | 06:17 PM
Big Phat R's Avatar
Your rear wing is too big and causing too much downforce.
try installing a smaller one - like this:
Old Feb 24, 2003 | 06:25 PM
Rob :190:'s Avatar
Default Re: help with wheel spin (Big Phat R)
LOL
every once in a while somebody justifies Canada's existance
Old Feb 24, 2003 | 07:55 PM
vtec.dc2's Avatar
you can try to lower tire pressure - find out whats the safest pressure it for 205/55 tire... the lowest i run on the 205/50 is 31-33psi (cold)..
get a set of bf goodrich drag radials and it will handle at least 180whp with no wheel spin through first gear.
Old Feb 24, 2003 | 07:56 PM
migs's Avatar
Default Re: help with wheel spin (vtec.dc2)
Get some new tires.
Old Feb 24, 2003 | 07:59 PM
nfn15037's Avatar
Default Re: help with wheel spin (DemontunedlsT)
Id much rather have Falken Azenis then the soggy-sidewall T1-S. Not to mention Azenis are so cheap its rediculous!!
xelloss
32
Jul 29, 2007 06:07 AM
MasterSaif
Feb 24, 2004 08:44 AM
Project X
Jul 11, 2003 10:36 AM
wanttorace
Dec 4, 2002 03:16 PM
