help!! spoon header
Old Mar 5, 2003 | 06:23 AM
macdaddy's Avatar
Default help!! spoon header
yesterday i instaled my spoon header and high flow cat, but when i started the car
the check engine light came on..
is this to do with the o2 sensor??
or is it something else??
can anyone please help??
Old Mar 5, 2003 | 06:26 AM
Flux's Avatar
Default Re: help!! spoon header (macdaddy)
yes, double check the o2 sensor connections...
Old Mar 5, 2003 | 07:32 AM
R-Rated's Avatar
What kind of high flow cat are u using? If u are using a carsound cat then it is most likely the cat, but not saying 100% it is. Check the code, if it gives u a code 67 then its the cat. I have the same setup and problem.
Old Mar 5, 2003 | 07:58 AM
macdaddy's Avatar
Default Re: help!! spoon header (R-Rated)
thanx but does it affect the car at all?
Old Mar 5, 2003 | 08:26 AM
R-Rated's Avatar
No it should not assuming it is the cat.
Old Mar 5, 2003 | 09:43 AM
Big Phat R's Avatar
Did you reset the ECU after the install??
Old Mar 6, 2003 | 07:21 AM
macdaddy's Avatar
Default Re: help!! spoon header (Big Phat R)
yes i did and it went of for a sec, then it came back on
is there a way to fix this problem?
Old Mar 6, 2003 | 07:30 AM
B2FiNiTY's Avatar
What code are you getting?
Old Mar 6, 2003 | 08:03 AM
GencivicIII's Avatar
Most than likely your O2 sensor needs to be replaced. Happened to my Bro's ITR after JDM header install and Catco Cat. Check engine light took it to Acura and Acura said it was the O2 going to the Cat.
Old Mar 6, 2003 | 09:39 AM
macdaddy's Avatar
Default Re: help!! spoon header (GencivicIII)
does it have to bo relpaced with a stock o2? or do i need another kindof sensor or something like that?
Old Mar 6, 2003 | 09:46 AM
Nate B's Avatar
If it is infact a bad O2 sensor, replace it with stock. I still don't know what code you're throwing...that would help
Old Mar 6, 2003 | 09:51 AM
97 TYPE-R 312's Avatar
Default Re: help!! spoon header (OG Bizzle)
hmm.. I've never thrown a light with my SPOON header and SMS cat.... Just an FYI.
Thanks,
Victor
Old Mar 6, 2003 | 09:59 AM
macdaddy's Avatar
Default Re: help!! spoon header (97 TYPE-R 312)
i know how to check the codes but i dont know how to read them (short flash -long flash) something like that
Old Mar 6, 2003 | 10:02 AM
SpoonEK2's Avatar
count the flashes. Long flashes are tens digit and short flashes are ones digit. so 6 long and 7 short is a code 67...cat operating below threshold/efficiency.
Old Mar 6, 2003 | 10:08 AM
macdaddy's Avatar
Default Re: help!! spoon header (SpoonEK2)
thanx alot guys!
i will check after work and let you know what code it is throwing at me
hopefully i can fix this prob...
Old Mar 6, 2003 | 12:09 PM
ITR21's Avatar
here is a link for you to book mark incase you throw a code in the future.
http://www.team-integra.net/sections...k+engine+light
schumi
Nov 22, 2006 12:30 PM
Another_Teg_Owner
Dec 15, 2003 11:11 PM
onyx00
Apr 16, 2002 01:00 PM
hondachick81
Oct 6, 2001 10:05 AM
