Help someone!!!
Old Dec 13, 2001 | 06:07 PM
inochi's Avatar
New User
Default Help someone!!!
My friend just installed a 5 zigen fireball exhaust system into his 01 gsr. The engine light came on and the spedometer is not working at all. Just now the abs turned on and now his car wont start. Does anyone know whats going on here? Also we noticed, while we were driving, that when we used the blinker the radio would blink with the signal light. Also on the freeway, in 5th gear, the acceleration shuts down even though his foot is on the pedal. Someone help out please. We are in some desperate need!!! thanks in advance
Old Dec 13, 2001 | 06:19 PM
EG8R's Avatar
Default Re: Help someone!!! (inochi)
All that because of a muffler....??? Weeeeeeeeiiiiiiiiiiiird.
Old Dec 13, 2001 | 06:25 PM
Dr Pooface's Avatar
Default Re: Help someone!!! (mr. skelly)
Sounds like you damaged several things during the install.
Old Dec 13, 2001 | 06:27 PM
FusionITR's Avatar
jeez...................i dont think install a muffler can do all this, did u put it on backwards or something?
Old Dec 13, 2001 | 06:38 PM
Darin D.'s Avatar
Default Re: Help someone!!! (FusionITR)
did you pull off any engine ground wires during the install?..having no engine grounds can cause strange electrical problems.
Old Dec 13, 2001 | 06:44 PM
inochi's Avatar
New User
Default Re: Help someone!!! (Willis)
Everything was just a bolt on. Nothing was removed except bolts and gaskets..but they were put back on. The top heat shield is still on and it rattles like crazy too. We just tried starting the car and it started back up again and the signal light is not blinking with the radio, but I dont know if thats gonna last.
Old Dec 13, 2001 | 06:45 PM
STOLEN - ITR 98-0652's Avatar
This has to be a troll...
Old Dec 13, 2001 | 06:46 PM
inochi's Avatar
New User
Default Re: Help someone!!! (ITR 98-0652)
troll?
Old Dec 13, 2001 | 06:54 PM
Chris's Avatar
Check the 02 sensor...did you mess with the one in the CAT?
Old Dec 13, 2001 | 08:27 PM
inochi's Avatar
New User
Default Re: Help someone!!! (Dr Pooface)
what do you mean?........nothing happened when i put my aem cold air......why my catback?
Old Dec 13, 2001 | 08:29 PM
Type Goch's Avatar
New User
because your aem CAI doesnt have an O2 sensor. check the plugs on your cat
inochi's Avatar
New User
no....everything is put on right
Old Dec 13, 2001 | 08:33 PM
Type Goch's Avatar
New User
so what exactly did you mess around with while you were down there?
inochi's Avatar
New User
Default Re: Help someone!!! (Type Goch)
what should i check for?
Old Dec 13, 2001 | 08:41 PM
inochi's Avatar
New User
i know.......when i put a greddy cat on my si........nothing happened
Old Dec 13, 2001 | 08:59 PM
inochi's Avatar
New User
you think my o2 got loose when i used the air gun
Old Dec 13, 2001 | 09:01 PM
Chris's Avatar
check the wires for the 02.
Old Dec 13, 2001 | 09:57 PM
inochi's Avatar
New User
Default Re: Help someone!!! (Chris)
check if it is loose......unpluged......burned out.....
AdRoz
Feb 19, 2009 06:32 AM
civicdxguy
Jan 29, 2007 05:06 PM
Typiko512
May 24, 2003 08:28 AM
ITR632
Apr 19, 2003 08:26 AM
inochi
Dec 13, 2001 07:00 PM
