help quick! need help on intake
Old Sep 17, 2002 | 05:18 PM
zer0zer0 TypeR's Avatar
Default help quick! need help on intake
can you tell me what i do with the stock lines? i drew some high quality arrows to show what i need help on. TIA
i know the bottom one with the white arrow connected to the intake manifold is a radiator or something line but do i just leave all this stuff or can i take it out? if i can take it out how?
Old Sep 17, 2002 | 05:19 PM
uNF$@#!'s Avatar
Default Re: help quick! need help on intake ('00TypeR)
get some tubing for the other connection and rip out the stock tubing all together, or just leave it as is.
or if you feel REALLY talented with a hacksaw, you can hack the tubings apart.
[Modified by Soup ****, 9:20 PM 9/17/2002]
Old Sep 17, 2002 | 05:43 PM
Default Re: help quick! need help on intake (Soup ****)
it's ok to just leave it as it is right? i mean other than the fact of repositioning it so it doesn't get in teh way of anything.
Old Sep 17, 2002 | 06:18 PM
jdmspoonitr's Avatar
it's not that hard to take off those line and just get one single rubber line to get rid of those metal lines. It doesn't make any performance difference, but I did it when I got sick of accidentally touching the hot metal. Besides if you let it sit, it might melt the clearcoat on ur intake. The metal line messed up my AEM.Just a warning. IF you had AEM before, they should have provided you with a line to replace that metal one.
Old Sep 17, 2002 | 06:29 PM
Tommy_Gunns's Avatar
Here's what you need to do:
Get rid of that metal tubing system all together. You will notice that either of the rubber coolant lines is long enough to connect from the intake manifold to the block...use that to connect the two points.
It's not rocket science, just look at the system and you'll figure it out. Make sure your car is cool before attempting this or you might burn yourself.
Old Sep 17, 2002 | 06:31 PM
Oh BTW, you should put some hose clamps on that blue silicone hose of yours. And don't tell me you got no clamps cause I can see 2 that you are not using at the moment (the ones you circled in the first pic).
[Modified by Tommy_Gunns, 10:21 PM 9/17/2002]
Old Sep 17, 2002 | 06:32 PM
Default Re: help quick! need help on intake (Tommy_Gunns)
You should also remove the resonator box if you haven't already done it. You got no use for it now that you have a J's intake system.
Old Sep 17, 2002 | 07:32 PM
i removed the resonator a long time ago and thx for the tip about the clamps, i just ran outside and did that, totally forgot!
Old Sep 17, 2002 | 09:41 PM
MK Ultra's Avatar
If you have room, I'd use the metal line with the intake.
Shorten the piece of hose that goes to the valve cover to give you some room, then use another short piece of hose to attatch that to the intake tube. That way you don't spill coolant all over the place and you won't lose the stock part.
Old Sep 17, 2002 | 09:46 PM
hooptie157's Avatar
Default Re: help quick! need help on intake (MK Ultra)
mini breather
thekid_12
Apr 8, 2008 05:42 AM
agy2k2
19
Aug 14, 2006 05:19 AM
agy2k2
Aug 11, 2006 05:30 AM
