HELP QUICK!
Old Apr 28, 2002 | 01:44 PM
zer0zer0 TypeR's Avatar
Default HELP QUICK!
awww ****. i just got back from AutoX and was removing my racing wheels off. one of the lugnuts would NOT come lose. so i pushed it with all my strength and bam, the whole damn screw breaks off into one of the lug nuts. wtf?!?! how much is this gonna cost to fix? am i gonna have to replce the whole thing? argh! will i be able to just drive regularly on my car until i can take it to the dealer tomorrow? CRAAAP i hope it's not expensive.
Old Apr 28, 2002 | 01:53 PM
Default Re: HELP QUICK! ('00TypeR)
bah help!!
Old Apr 28, 2002 | 02:04 PM
Tweakmeister's Avatar
dun worry, the lug bolts are easy to replace, it shouldn't be more than $50-$100 ($100 being if your dealer likes to ream you).
Since you have 5 lugs with the R you should be okay driving it around. That being said, drive very carefully and go easy. I would drive it to the dealer first thing just to be on the safe side (ofcourse I baby my car).
Old Apr 28, 2002 | 02:27 PM
Default Re: HELP QUICK! (Tweakmeister)
whew thx tweak, i was freaking out for a second. but yes first thing tomorrow the baby goes to the dealer.
Old Apr 28, 2002 | 03:15 PM
Eric R's Avatar
What? With that money I can replace almost all my studs!
Man, go to the parts dept. and buy one stud and nut for your R and do it yourself. It's very easy!
Just need a jack, a wrench, and a hammer. Bah!
Old Apr 28, 2002 | 03:22 PM
Asahi's Avatar
Default Re: HELP QUICK! ('01ITR#950)
actually you have to pull the hub so you needa 32mm socket too. If any of the others look worn out replace them at the same time they should only charge you for the lugs. I would say $30 and $50 is pushin it, it won't take them an hour.
Old Apr 28, 2002 | 03:24 PM
Eric R's Avatar
Default Re: HELP QUICK! (Asahi)
Uh???
Old Apr 28, 2002 | 06:39 PM
Dropspeed's Avatar
You should propably look at/ think about, why it happened to prevent it from happening again. Studs usually don't "just"get weak and snap & lug nuds don't usually seize. Did you cross-thread it? Did you use a torque wrench to install it properly? Last but not least Anti-seize is your friend.
Mattj
Old Apr 28, 2002 | 06:58 PM
Default Re: HELP QUICK! (Dropspeed)
yea i was thinking maybe i cross threaded it but i don't think that's it cause i rims every other week. oooo and i have another problem, why the **** do i keep losing lug nuts? i'll just be driving and than i look at me wheels when i get outta my car and i lose a lug nut, wtf happened twice. i think i'm retarded and can't tighten lug nuts. argh.
Old Apr 28, 2002 | 07:01 PM
Dropspeed's Avatar
Problem solved!!! J/K
Are you using a torque Wrench?
Old Apr 28, 2002 | 07:07 PM
yoshi234's Avatar
I shoot brides
Snap On torque wrench
Old Apr 28, 2002 | 07:35 PM
tecnic1's Avatar
I just beat the stud past the brake shield and then beat the new one back in....hed to rethread it though...probibly not the easyest way to do it..
Old Apr 29, 2002 | 01:51 AM
acuracing's Avatar
Default Re: HELP QUICK! (tecnic1)
Honda studs are weak. They're so cake to replace though. I think I'm a pro at it. IT should take you no more than 10 minutes tops. All you have to do is take of the caliper, rotate the rotor/hub til the broken stud lines up with a hole in the brake shield, and just whack that **** out. After that just install the new stud in the hub/rotor and put a lugnut on it and tighten it so that pulls the stud into the rotor/hub assembly. I bought the stud and lugnut from a Honda dealership for no more than $2 total for the two. Good luck. It's nothing to sweat about. You don't need to remove the hub.
Old Apr 29, 2002 | 02:01 AM
SpeedPak's Avatar
Default Re: HELP QUICK! (acuracing)
locktite rules!
Old Apr 29, 2002 | 05:46 AM
Asahi's Avatar
THis is common if your wheels need a conical lug nut and you use stock acordn style nuts.
Old Apr 29, 2002 | 05:48 AM
sackdz's Avatar
Default Re: HELP QUICK! (SpeedPak)
Anti-sieze and loctite are opposites!
Old Apr 29, 2002 | 05:57 AM
H-PIMP's Avatar
Default Re: HELP QUICK! (sackdz)
Anti seize the ish out of your studs next time. One stud shouldn't cost that much to replace.
Old Apr 29, 2002 | 07:03 AM
Toda Party's Avatar
Default Re: HELP QUICK! (Storm Shadow)
invest in a torque wrench...i wouldn't be too happy If i get out of my car and there's lug nuts missing...and that's just for normal daily driving? imagine that happening in an autox or something
Old Apr 29, 2002 | 07:16 AM
KF_S2000's Avatar
Hole in the brake shield huh? Interesting, I'll have to check that out next time I'm under there.
Old Apr 29, 2002 | 08:26 AM
Nick248's Avatar
Default Re: HELP QUICK! (kf_Type-R)
I F'd up once ..... I torqued my lug nuts the day before an AutoX and never checked them during. I drove home 60 miles away crusing at 85ish.
I then drive to get some dinner and on my way back home, I hear a clicking/rubbing noise. For the life of me, I couldn't figure out where the sound was coming from. I had my father-in-law drive the car while I was outside looking for the source.
My wife then points out that i'm missing a few lug nuts. I checked and to my surprise, two lugs were missing, one was on its last thread, another was loose. Only one lug was in tight!
it could have been disaterous!
-Nick
[Modified by Nick248, 9:27 AM 4/29/2002]
Old Apr 29, 2002 | 04:38 PM
Default Re: HELP QUICK! (Nick248)
the funny thing is right before one of my races, somebody pointed out that i was missing 2 lug nuts, i was like wtf. i was so pissed so i had to borrow 2 nust from a lady with a 89 civic lol. thank god she was coo about it. damn now i gotta go install the damn stud.
triumph_013
Feb 5, 2013 11:25 AM
O RLY
Apr 4, 2007 04:53 PM
sjteg
Jul 13, 2003 06:39 PM
typer464
Sep 28, 2002 05:12 PM
BrandonClaps
Aug 31, 2002 01:19 PM
