Help: Problem putting car on jackstands
Old Nov 26, 2003 | 11:15 AM
Nishant's Avatar
Default jacking up the car...problem (did search already) HELP!!!!
I am trying to put my R on jackstands for winter storage. I have a 3.5 ton jack. The max lift is either 21 or 22 inches. I used the rear tow hook to jack it up. Car goes up fine but there isn't enough room for me to fit the stands in. Its about an inch or 2 short of me being able to squeeze them onto the stand points. Am i doing something wrong? my stands are also 3.5 ton. it was whole craftsman set i got.
Old Nov 26, 2003 | 11:22 AM
Big Phat R's Avatar
Default Re: jacking up the car...problem (did search already) HELP!!!! (swtxaznrac3r)
put the car on pieces of wood to start (like pieces of 2x4") - that will get the 2" you need.
get someone to help you too.
Old Nov 26, 2003 | 11:39 AM
Nishant's Avatar
Default Re: jacking up the car...problem (Big Phat R)
i'll try it but wouldn't putting a 2x4 under the jack be better? as for help, ehh i'm a loner on this one
Old Nov 26, 2003 | 11:44 AM
JOEP's Avatar
The problem is your using the rear tow hook as your lift point which is higher up.... You dont need to do it from there. I put my car on jackstands and they way I always do it is to jack it from the points on each corner. I put one jack stand on at a time.... its a little trickier but thats the way I and a ton of my buds always do it...
Start from the front left, rear right, rear left, front right.... hope this helps...
Old Nov 26, 2003 | 11:45 AM
typer_801's Avatar
Default Re: jacking up the car...problem (swtxaznrac3r)
Yes, you only put wood under the tires when you can't get the jack under the car (lowered too much).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swtxaznrac3r &raquo;</TD></TR><TR><TD CLASS="quote">i'll try it but wouldn't putting a 2x4 under the jack be better? as for help, ehh i'm a loner on this one </TD></TR></TABLE>
Old Nov 26, 2003 | 12:00 PM
Big Phat R's Avatar
That only makes your jack taller and harder to get under the car.
Think man!
Old Nov 26, 2003 | 12:03 PM
Nishant's Avatar
jack goes under the car fine...problem is that it doesn't lift the car high enough for me to put the stands in
Old Nov 26, 2003 | 12:06 PM
SamC's Avatar
i put wood blocks on the jack, so the woods is between jack and the jack point. this way you can jack up the car. The wood on the bottom of the jack works but the jack moves.
I put woods under the tires for more clearance if needed.
Old Nov 26, 2003 | 12:08 PM
Nishant's Avatar
Default Re: jacking up the car...problem (SamC)
wood seems to be the best way...i just gotta go find some. thanks for the help guys/gals!!!
Old Nov 26, 2003 | 06:00 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">That only makes your jack taller and harder to get under the car.</TD></TR></TABLE>
He's jacking it up with the rear tow hook... plenty o' room... his problem is that his jack sucks and wont lift high enough to put stands under the rear jack points
Think man!
Old Nov 26, 2003 | 08:40 PM
sjracer's Avatar
Default Re: jacking up the car...problem (.RJ)
Have you tried jacking from the rear sub-frame? Don't jack from the tie bar, but on one of the main ends. That's where i jack from when i need more height on my RSX. Good luck.
Old Nov 26, 2003 | 08:47 PM
Batoutahell's Avatar
If you jack up the front end first, you will have a little more clearance for jackstands in the back. That may be enough to give you the 1-2 inches you need.
Old Nov 27, 2003 | 05:12 AM
JiggyKooAndy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SamC &raquo;</TD></TR><TR><TD CLASS="quote">i put wood blocks on the jack, so the woods is between jack and the jack point. this way you can jack up the car. The wood on the bottom of the jack works but the jack moves.
I put woods under the tires for more clearance if needed.</TD></TR></TABLE>
I have tried this...i had to let it down right away cuz the wood was starting to crack. This was a 2x4 btw.
Old Nov 27, 2003 | 08:10 AM
nsxtasy's Avatar
H-T Order of Merit
There's no need to put the car on jackstands for winter storage. The idea of tires "flat spotting" during storage is a myth. They will return to normal shape as soon as you drive down the street.
Just leave your car on the ground.
Old Nov 27, 2003 | 09:34 AM
B2FiNiTY's Avatar
Default Re: jacking up the car...problem (nsxtasy)
I believe it is also better for your suspension.
Old Nov 27, 2003 | 10:30 AM
kkim's Avatar
solution is to buy some jackstands that are a bit shorter. I have the same problem depending on which of my 3 sets of jackstands I try to use.
While using wood on the end of your jack will work, I have had the wood move at times when I was using a jack without enough reach. I never had the wood slip of and now that I think back on it, I was lucky nothing ever disastrous ever happened.
Play it safe and go look for some stands at the local auto parts store that will fit under the space alloted. Better to be safe than sorry.
Old Nov 27, 2003 | 05:13 PM
Nishant's Avatar
Default Re: jacking up the car...problem (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">I believe it is also better for your suspension.</TD></TR></TABLE>
whats better, jack stands or no jack stands? even the owners manual says to put it on stands for storage if possible
Old Nov 27, 2003 | 05:24 PM
Dave-ROR's Avatar
Default Re: jacking up the car...problem (kkim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kkim &raquo;</TD></TR><TR><TD CLASS="quote">solution is to buy some jackstands that are a bit shorter. I have the same problem depending on which of my 3 sets of jackstands I try to use. </TD></TR></TABLE>
Exactly. A jack with a 21" lift height should be PLENTY for the rear tow hook. Use some two ton jacks, not those semi truck 3.5 ton ones. (at least, the 3.5 ton ones I've seen are HUGE compared to the 2 ton ones, dunno about sears though, but any normal car jack stands should be fine)
zomart
Aug 6, 2003 02:27 PM
TrueZen
Jan 3, 2003 01:13 PM
