HELP!: Problem installing Test pipe
Old Aug 1, 2002 | 08:04 PM
zer0zer0 TypeR's Avatar
Default HELP!: Problem installing Test pipe
i have 2 questions,
1) i have the Godspeed TP and a jdm kakimoto N1. i lined up where the bpipe and testpipe meet, the triangular shaped with 3 holes, and the Godspeed Testpipe holes don't line up with the Kakimoto Bpipe. will the carsound 94006 cat match up with kakimoto bpipe or am i gonna have to get some custom work done?
2) what is the difference between carsound cat 94006 and 94106? the muffler guy told me the only difference is the 94106 has some kinda inner tubing or something. it looks exactly like the 94006 pix. can anybody help?
Old Aug 1, 2002 | 08:15 PM
SMSP's Avatar
Default Re: HELP!: Problem installing Test pipe ('00TypeR)
1. First I don't think your test pipe will fit without modification. I think guys use smaller bolts so they can bolt the test pipe to the cat back system. If you are using a JDM header with a JDM cat back i.e. the Kakimoto R then the 94006 won't fit.
The 94106 is 3" shorter then the 94006, but the oval style is the same.
Old Aug 1, 2002 | 08:20 PM
Default Re: HELP!: Problem installing Test pipe (SMSP)
bah after doing a search and reading about 15 posts ALL the way through i got an answer. quick questions smsp, should i get the 94166 which is the same as 94106 but the 94166 has to O2 bungs. should i get the one with or without the bungs?
Old Aug 1, 2002 | 08:22 PM
Jsracingintegra
Guest
Posts: n/a
Its the test pipe. Godspeed test pipes are the biggest pieces of crap. They dont fit well or at all, the cat material breaks so the CEL comes on, and it usually too long.
I got a test pipe from SMSP and the fit was perfect. A direct bolt on!
Old Aug 1, 2002 | 08:32 PM
SMSP's Avatar
If you are OBDII then you'll need the 94166
Old Aug 1, 2002 | 09:38 PM
sackdz's Avatar
Did you buy it directly from Godspeed? If so I think Dan would be more than filling to heav it rewelded for you free of charge.
[Modified by sackdz, 1:38 AM 8/2/2002]
Old Aug 1, 2002 | 11:38 PM
Default Re: HELP!: Problem installing Test pipe (sackdz)
i actually got the TP from 00-ITR-373. you think he's willing to? isn't the godspeed site down? do you know how i could getta hold of him?
Old Aug 1, 2002 | 11:39 PM
jonas's Avatar
godspeed.hack.net
if you type in http://www.godspeed.hack.net it doesnt work
Old Aug 1, 2002 | 11:45 PM
Art Vandeleigh's Avatar
Default Re: HELP!: Problem installing Test pipe (jonas)
just run a cat. the couple of ponies you gain is not worth killing the earth.
testpipes
Old Aug 2, 2002 | 12:46 AM
4-1-1's Avatar
Default Re: HELP!: Problem installing Test pipe (up-youRs)
testpipes
is that true?
Old Aug 2, 2002 | 12:49 AM
Default Re: HELP!: Problem installing Test pipe (4-1-1)
who knows but his post has moved me to getta cat!
28
Feb 7, 2011 04:54 PM
type-GGSR
Mar 4, 2008 09:25 PM
spyderman_8_2
16
Jun 27, 2005 04:40 PM
Phatch99
Jul 27, 2004 07:03 PM
swarsing
Dec 17, 2002 08:29 PM
