Help with O2 sensor!!!
Old Mar 29, 2003 | 07:47 PM
Art Vandeleigh's Avatar
Default Help with O2 sensor!!!
i cant seem to get the O2 sensor off. i know i can unplug it, (the one that goes into the header) but i tried pushing the tab all the way in to no avail.
is there more than 1 tab that i need to puch in? if your looking up from the nottom, you can see 1 push in tab. is there another one somewhere on top that i need to push in too?? thanks!!
Old Mar 29, 2003 | 07:56 PM
milanoGSR's Avatar
Default Re: Help with O2 sensor!!! (Art Vandeleigh)
put some strength into that pull boy!
Old Mar 29, 2003 | 07:58 PM
ITR21's Avatar
Default Re: Help with O2 sensor!!! (milanoGSR)
only one tab
so is there only 1 push tab that needs to be pushed in to get it off?? i can only see 1 push tab when looking up from the bottom of the car. is there another one up top that i just cant see?thanks!!
Old Mar 29, 2003 | 08:07 PM
JDM CTR '00's Avatar
only one yes just push the tab in and pull like a ****
Old Mar 29, 2003 | 08:08 PM
Default Re: Help with O2 sensor!!! (ChargedSi99)
thanks all!!!!! going to do it right now.
Old Mar 29, 2003 | 08:09 PM
DarthLuder's Avatar
New User
Yep those plugs are a bitch. Simple way is to stick a really small wrench or screwdriver into the tab. Which will hold the tab down. Then all you have to do is pull them apart.
Old Mar 29, 2003 | 08:27 PM
98itR484's Avatar
Default Re: Help with O2 sensor!!! (ITR GURU)
any luck???
Just pull, dont worry you wont break/cut/disconnect anything
RallyRedGT-V6
Jul 30, 2004 08:32 PM
icon_race_eg
14
May 5, 2004 05:49 PM
96b18c
Jun 27, 2003 10:52 PM
Art Vandeleigh
Mar 29, 2003 10:48 PM
tek_civic
16
Feb 19, 2003 09:58 PM
