Help installing shocks
Old Dec 20, 2001 | 01:00 PM
99ls's Avatar
Default Help installing shocks
Has anyone installed shocks/springs completely on their own with no help? How did you do it?
I remember when I did this a while back, I had trouble getting the forks back onto the LCA without help from someone pushing down on the LCA. For those who have done this completely on your own, how did you manage to get the things back on yourself?
Old Dec 20, 2001 | 01:15 PM
norice's Avatar
Default Re: Help installing shocks (99ls)
It has been a while since I did my swap but I had no trouble pushing them down. Perhaps you did not disconnect the anti-roll bars?
Old Dec 20, 2001 | 01:18 PM
Big Phat R's Avatar
Use a pry-bar
Old Dec 20, 2001 | 01:25 PM
RTW DC2R's Avatar
Yeah ive done it on 2 cars, including my IT<FONT COLOR="red">R</FONT>. I vaguely remember just standing on the hub/rotor and reaching under to get the shock lined up into the LCA. Make sure you put the shock in and attach it loosely at the top of the strut tower first so you dont have to worry about holding it while lining it up with the LCA.
[Modified by 12secTypeR, 5:26 PM 12/20/2001]
Old Dec 20, 2001 | 04:07 PM
KF_S2000's Avatar
Default Re: Help installing shocks (norice)
----&gt;
Yep, that's exactly what it sounds like he's fighting with. Either use the pry bar like someone already mentioned, or unbolt the sway bar.
Old Dec 20, 2001 | 11:34 PM
99ls's Avatar
Default Re: Help installing shocks (kf_Type-R)
I've been following the directions off the site at http://www.bseries.net with no mention of removing the sway bar. Anyone want to give me a step-by-step on how to unbolt it?
Thanks.
[Modified by 99ls, 10:58 AM 12/21/2001]
Old Dec 21, 2001 | 09:59 AM
99ls's Avatar
ttt
Old Dec 21, 2001 | 11:19 AM
Yell00ITR's Avatar
Just remove the control arm...that is what I do on the rears. It takes an extra 2 minutes and makes everything SO much easier. When reinstalling, put the side that the fork goes on first, lining things up. Put the bolt in place but dont tighten. Now, connect the control arm back to its mounting point. It may take a little elbow grease to get things lined up but it does work. Then, tighten everything up.
[Modified by Yell00ITR, 12:20 PM 12/21/2001]
CRX_Type_R
Jan 23, 2005 12:45 AM
prelude93si
Aug 10, 2003 06:13 PM
99ls
Dec 22, 2001 06:11 PM
