Help installing header
Old Feb 28, 2002 | 06:46 PM
YellowSpeed's Avatar
New User
Default Help installing header
I just install the comptech 4-2-1. Install the header but can't get O2 out of stock header. NEED HELP!!!!!!!!!!!!!!!!!
Old Feb 28, 2002 | 06:49 PM
mugenintegra16's Avatar
Default Re: Help installing header (YellowSpeed)
Just unscrew it snap on makes a special tool for that.
FroggyR's Avatar
Hey man, lefty losey, righty tighty....... It also has a bit of a kind of lock tite.... good luck with ur warrantee now...
Old Feb 28, 2002 | 06:52 PM
New User
It like that dam thing dosn't want to come out. The deal out here will warrantee you car if you have the basic bolt on's but no more
Old Feb 28, 2002 | 06:53 PM
Comtechgsr2000s's Avatar
New User
Get a cresent wrench and turn counter clock wise
Old Feb 28, 2002 | 06:54 PM
Flux's Avatar
I thought Comptech parts did not void the Acura warranty - or is that just if it is installed at the dealership?
Old Feb 28, 2002 | 07:28 PM
SamC's Avatar
Default Re: Help installing header (Flux)
Didn't know Header will void warranty...how about other headers beside comptech?
Old Mar 1, 2002 | 11:17 AM
New User
Default Re: Help installing header (Mugenblkgsr2000)
Finally got the O/2 off and installed it. I’m get some rattling noise with I first accelerate, that isn’t normal is it. I know my Apexi N1 makes noise but now more noise, Dam. I haven’t noticed any really power gains. How did that get some much power out of that header; when they did the great header test?
Old Mar 1, 2002 | 11:23 AM
New User
Default Re: Help installing header (FroggyR)
After I install the header I install an Air/Fuel guage and the dam thing doen't seem to be working right. When my car is Idling the gauge will stay in lean and then jump to rich, and then jump back to lean, is this normal.
Old Mar 1, 2002 | 11:53 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Why would a header void yor warrenty? The laws on this thing clearly state that the dealer has to prove the mods caused the problem, thay can't just void your waarenty. If they do, call a lawyer.
Old Mar 1, 2002 | 01:15 PM
Isaac's Avatar
New User
Default Re: Help installing header (newt2)
I guarantee that they can somehow relate header installation to a failed motor. Regarding the installation, if you haven't done so yet, I would advise you to reset the ECU. The safest way and preferred is to pull out the fuses in the engine bay. I believe they are the 2 in the uppoer most left corner, but I'm not definite. That will probably help. Secondly, the noise is an exhaust leak if it doesn't sound normal. Make sure your gaskets are ok at each connection, oh yah, just the header/cat connection and then retighten everything.
crazyhorse2011
11
Feb 23, 2017 06:40 PM
^^ALUCARD^^
Honda S2000
11
Sep 27, 2006 11:53 PM
Cesare1987
44
Nov 25, 2005 02:07 PM
makeshift
Jul 14, 2004 06:27 AM
dlslvtch21
Mar 8, 2002 07:19 AM
