Help!! emissions problem
Old May 9, 2006 | 03:12 PM
Kyle244R948's Avatar
Default Help!! emissions problem
Well I have been having problems with inspection, I am not able to pass the emissions test. I have changed my oil, put a new fuel filter on, cleaned up the spark plugs and have also put a SMS catalytic convertor on my DC jdm header and T1R exhaust, that was running a test pipe before. The mods on my ITR are; Jdm Dc header, T1R exhaust, Skunk2 Cam gears(not tuned), aem fuel rail and intake. The hydrocarbns were at an astounding 728 and the co% were 9.13 . That is just two outrragous numbers and I have no idea why?!? I do have the CEL on, which is code number 54 which is CKF Sensor defective circuit. I dont see how this is because I have put a new one on recently and I even tried the little trick that you can do to make it think is works and I still have a CEL. Could it be my distributor? I just dont know what else could make me run soo rich. I am going to get my car tuned a soon as the new Neptune hardware is releaased but until then I needdd to pass emissions. Anyone know what could it be? Hopefully someone can chime in and help me out with this one. Thanks a lot!
Old May 9, 2006 | 03:32 PM
Default Re: Help!! emissions problem (Kyle244R948)
Here's a picture for your viewing pleasures
Just one of my favorites from honda-tech.
Old May 9, 2006 | 07:08 PM
pleasee helpp
Old May 9, 2006 | 10:17 PM
noopsITR's Avatar
what style header is it. i think if its 4-1 it wont pass. i tried to pass smog with a jdm oem 4-1 header and failed. i used my friends 4-2-1 header and passed on that try.
Old May 10, 2006 | 07:52 AM
Default Re: (noopsITR)
I do have 4-1 header i dont see why that would be a problem how many points did u drop on the test by switching headers? Anyone else?
Old May 10, 2006 | 09:09 AM
noopsITR's Avatar
dunno how many points but the techs at the shop said the exhaust flow is too high. i dunno, californias smog laws are gay. also, i had to use the stock piping, i was using 2.5" and swithed it out with the oem one.
Old May 10, 2006 | 10:01 AM
Well can anyone help me out with my CEL i dont know what to do about it and it is bugging the hell out of me and I think it might be causing me to run rich too.
Old May 10, 2006 | 11:49 AM
noopsITR's Avatar
disconnect your negative battery terminal for about a minute. sometimes that resets the CEL. it worked for me in an em2 civic before.
Old May 10, 2006 | 02:15 PM
emotionisdead's Avatar
Very Emergency!!
damn, those numbers are really high. i'm a smog tech in nevada and our limit on 81 and newer vehicles is 220 HC and 1.20% CO. simply put you are running overly rich at idle (high CO indicates that) causing you to have a misfire and spit unburnt fuel out the exhaust (HC indicate that.) see if you can borrow a wideband o2 sensor and see what your a/f at idle is. code 54 might put it in a limp mode of sorts. hope this info helps.
Old May 10, 2006 | 02:25 PM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: Help!! emissions problem (emotionisdead)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noopsITR &raquo;</TD></TR><TR><TD CLASS="quote">what style header is it. i think if its 4-1 it wont pass. i tried to pass smog with a jdm oem 4-1 header and failed. i used my friends 4-2-1 header and passed on that try.</TD></TR></TABLE>
WTF???
I cant think right now, do you have another dizzy you could swap in and see if it helps?
Old May 10, 2006 | 03:04 PM
Default Re: Help!! emissions problem (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">
WTF???
I cant think right now, do you have another dizzy you could swap in and see if it helps?</TD></TR></TABLE>
I could possible get one but it would be from a GSR, is that ok?
Old May 10, 2006 | 03:10 PM
GRAVEDIGGER's Avatar
probaby a bad cat or the 4-1.
Old May 10, 2006 | 03:24 PM
98DC2R's Avatar
Default Re: Help!! emissions problem (GRAVEDIGGER)
do you have a adj fpr?
Old May 10, 2006 | 04:59 PM
cjames235's Avatar
Default Re: Help!! emissions problem (98DC2R)
im running a 4-1 2.5" header with a 2.5" carsound cat/ spoon n1 catback and my car passes smog at near 0 on both HC and monoxide so i dont think either of those is your issue
im also running a chipped p28 and pass no problem what so ever......... however i do have a vafc and have tuned it so i bet your problem is in the fuel at idle........ mine is idling in the 15:1 area
Old May 11, 2006 | 08:02 AM
Default Re: Help!! emissions problem (cjames235)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAVEDIGGER &raquo;</TD></TR><TR><TD CLASS="quote">probaby a bad cat or the 4-1.</TD></TR></TABLE>
Old May 11, 2006 | 08:10 AM
The cat is brand new.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98DC2R &raquo;</TD></TR><TR><TD CLASS="quote">do you have a adj fpr?</TD></TR></TABLE>
No i do not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjames235 &raquo;</TD></TR><TR><TD CLASS="quote">im running a 4-1 2.5" header with a 2.5" carsound cat/ spoon n1 catback and my car passes smog at near 0 on both HC and monoxide so i dont think either of those is your issue
im also running a chipped p28 and pass no problem what so ever......... however i do have a vafc and have tuned it so i bet your problem is in the fuel at idle........ mine is idling in the 15:1 area </TD></TR></TABLE>
I believe its that too but i dont know how it could be like that though, I have done nothing with the fuel, I use ti have a vafc but got rid of it a year ago. Im thinking that the CEL code 54 might have put my car in "limp mode" but my car still can be ran through vtec with no problems, so i dont know. Will a GSR distributor work on my ITR or will the timing be different? thanks
Old May 11, 2006 | 03:03 PM
If your car is running really rich it can go bad in a month or so, Happened on my R twice.
Old May 11, 2006 | 03:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAVEDIGGER &raquo;</TD></TR><TR><TD CLASS="quote">If your car is running really rich it can go bad in a month or so, Happened on my R twice.</TD></TR></TABLE>
Well I have only driven it once(to go to the dmv) since I put the cat on. Im not trying to drive it until i fgure out what to do.
Old May 11, 2006 | 03:15 PM
Then that's not the problem. GL in fixing it!
Old May 11, 2006 | 04:18 PM
Very Emergency!!
like i said before, get a wideband on that bitch!!!! and then tune your idle accordingly.
the fact of the matter is, according to your numbers, is TOO MUCH FUEL AT IDLE!!
Old May 11, 2006 | 05:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emotionisdead &raquo;</TD></TR><TR><TD CLASS="quote">like i said before, get a wideband on that bitch!!!! and then tune your idle accordingly.
the fact of the matter is, according to your numbers, is TOO MUCH FUEL AT IDLE!!</TD></TR></TABLE>
No one around here has one, I think im going to try and get a Vafc from a friend and just tune from that. Hopefully it will workk.
Old May 12, 2006 | 02:49 PM
Anyone think a Vafc will help me out?
Old May 12, 2006 | 06:15 PM
anyone??
JesseCRX
Aug 1, 2008 05:00 PM
1_slow_crx
16
Jul 23, 2007 11:23 PM
oem_certified_accord
Jul 11, 2007 05:43 PM
SwedBoy2999
Sep 13, 2004 10:01 PM
Renegade
Nov 18, 2003 09:01 AM
