help: CEL code 65
Old Mar 12, 2004 | 05:05 AM
lePetitePrince's Avatar
Default help: CEL code 65
I am running on P28 obd I ecu wiht hondata s200, now I get a CEL on and I can't seems to go over 4000rpm. I tried to check what code it is, I follow the instruction on C-speed website, but my ecu light jsut won't flash.
So I plug my obdII oem ecu back in, I get code 65, which is Oxygen Sensor Heater (Secondary) malfunctioning or defective oxygen sensor heater.
Because I am running a test pipe, I think that is why I am getting this code? right? but then why would I not able to get over 4000rpm on my hondata? seems is like cutting off my fuel? is just keeps bogging over 4000rpm. BTW, when I plug my OBDII oem ecu back in, I don't get that 4000rpm problem, so I believe is the HOndata that is screwing up?
Modified by lePetitePrince at 2:18 PM 3/12/2004
Old Mar 12, 2004 | 05:15 AM
sgT's Avatar
sgT
Default Re: help: CEL code 65 (lePetitePrince)
is the light on the hondata box constant on or is it blinking?
Old Mar 12, 2004 | 05:17 AM
Default Re: help: CEL code 65 (sgT)
mine is a s200 unit..I do'nt even see a light comes on..is there suppose a light? sorry that I forgot b/c I just took the car out from winter storage. I totally forgot should thre be a light on the hondata
Old Mar 12, 2004 | 05:19 AM
sgT's Avatar
sgT
yes there should be a light
Old Mar 12, 2004 | 05:39 AM
oh **** then..hte light is not on..something wrong wiht the hondata then?
Old Mar 12, 2004 | 05:44 AM
sgT's Avatar
sgT
yup.
check the cable make sure its plugged in.
kardal86
May 24, 2010 08:59 PM
kardal86
May 24, 2010 05:45 PM
tecnic1
Nov 25, 2006 07:36 AM
l2yanE
Oct 22, 2005 12:58 PM
KiNG $h!t
Nov 21, 2004 12:03 PM
