ground strap?
Old Aug 17, 2005 | 03:51 PM
a1320addict's Avatar
Default ground strap?
got the day off tomorrow...and want to replace my factory grounds....where can i find the "ground strap" ive seen on here multiple times?
Old Aug 17, 2005 | 04:13 PM
white rocket's Avatar
Default Re: ground strap? (yehiknowrite)
Check the sponsors in the Per. section. There are many options. T1R, NRG, HKS, Buddy Club, etc.
Old Aug 18, 2005 | 06:38 AM
Default Re: ground strap? (white rocket)
im not looking for a grounding kit....thats all i found in the sponsor's section...the grounding strap from the chasis to the valve cover?
Old Aug 18, 2005 | 12:19 PM
citrus3000psi's Avatar
U mean just a piece of wire? Really you just want the most conductive piece of metal to give you the lowest resistance across.
So try to get some Electrolytic Tough Pictch Copper...
If you cant find any of that just look for some silver. C110 Silver flash is good.
Old Aug 18, 2005 | 12:22 PM
Haleiwa-Brando's Avatar
Default Re: (citrus3000psi)
If you go to wall-mart back to where they sell the batteries, there is 4 gauge negative battery wire that they sell in various lengths that is more than sufficient in grounding your valve cover to the chasis. Cost you like $4.00 and it already has crimped ends on it.
Old Aug 18, 2005 | 01:48 PM
Default Re: (Haleiwa-Brando)
thanks everyone for the replies...but im looking for the ground "strap" it almost looks like a fruit by the foot...
Old Aug 18, 2005 | 05:22 PM
mugenracer's Avatar
It'll be on the front of the engine...its a bit of wire bolted to the front panel and the front right hand side of the valve cover........lol!!!!!!!!!
Old Aug 18, 2005 | 07:50 PM
Default Re: ground strap? (mugenracer)
ok......i know what a factory ground is
i am looking for something like this:
Old Aug 18, 2005 | 07:57 PM
migs's Avatar
Here you go man.
Its under $20 at Honda.
Old Aug 18, 2005 | 08:01 PM
HYREV2NR's Avatar
Does anyone besides me think the factory grounds are not worth a flip? I'm tinking of making my own w/ good stereo 4 guage cable & gold plated terminals.
Old Aug 18, 2005 | 08:11 PM
Default Re: (HYREV2NR)
thanks migs....
does anyone know what else i was referring to? they are like 1 inch wide and very thin....
Old Aug 18, 2005 | 08:29 PM
Mugen Mike's Avatar
Default Re: (yehiknowrite)
This what you're looking for?
Old Aug 18, 2005 | 09:35 PM
KOALA YUMMIES's Avatar
Default Re: ground strap? (migs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs &raquo;</TD></TR><TR><TD CLASS="quote">Here you go man.
Do you see Mexico on the part # tag too?
Old Aug 18, 2005 | 11:38 PM
Default Re: ground strap? (KOALA YUMMIES)
yes...exactly what mugen mike posted...where can i pick that up?
Old Aug 18, 2005 | 11:47 PM
Bbasso's Avatar
http://www.amgndsys.com/TYPES.html
Is this what your looking for?
Old Aug 18, 2005 | 11:49 PM
Default Re: ground strap? (Bbasso)
yes...finally...thank you
bbasso
Old Aug 18, 2005 | 11:53 PM
Bbasso's Avatar
It had to be the easiest thing to find...
Google.
"ground straps"
results.
Old Aug 19, 2005 | 01:49 AM
strepto's Avatar
I really love the infamous Type-R Cylinder-Head-To-Chassis brown cable. Its so... sweet.
Old Aug 19, 2005 | 06:12 AM
GPNY's Avatar
Default Re: ground strap? (strepto)
Napa or Autozone sell those flat groundstraps...
Old Aug 19, 2005 | 09:17 AM
BolivianDc2's Avatar
Default Re: ground strap? (GPNY)
Tailor Braided Ground Straps
http://store.summitracing.com/...h.asp
Old Aug 19, 2005 | 09:43 AM
Jowee's Avatar
Default Re: ground strap? (BolivianDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BolivianDc2 &raquo;</TD></TR><TR><TD CLASS="quote">Tailor Braided Ground Straps
Nice flip flops
Your radiator cap is on backwards too
Old Aug 19, 2005 | 10:35 AM
Arsenal's Avatar
Default Re: ground strap? (Jowee 1162)
What happens if you don't run the ground? I don't have it but the car runs fine?
Old Aug 19, 2005 | 11:47 AM
01-0720's Avatar
Default Re: ground strap? (Arsenal)
from my understanding the one that connects to the valve cover is more of a backup ground, the main ground is on the pass side by the transmission thats the main ground
but im probally wrong
Old Aug 19, 2005 | 12:11 PM
Default Re: ground strap? (01-0720)
Because I'm a Foreman Electrician, I personally feel that the braided unit, is not too good with grounding. 4 - 6 gauge wire (fine stranded) and shielded will work much better. You can even take it a step further and grind the paint off the radiator support that would be just under the grouding end. You can do the same for the frame rail where the grounding wire connects to the sub frame. You can go even further and create your own grounding system, starting from the battery and working the wire all the way around the engine bay starting from the negative battery terminal to all the main grounding areas (water thermostat, valve cover to radiator support, tranny to chassis) and go back to the negative battery terminal.
Simply by looking at that braided unit makes me think that this is not giving the electrical current the path of least resistance. Your goal is to have the current smooth and controlled (shielded/stranded wire - finer strand the copper is the better) not something that is braided, spread out, and not made of copper.
Just my .02
Old Aug 19, 2005 | 12:29 PM
Chris F's Avatar
Default Re: ground strap? (Haleiwa-Brando)
No one mentioned this yet, but--
This is NOT a "valve cover" ground. It is grounding one of the bolts from the valve cover to the block. That bolt is insulated from the valve cover by a rubber grommet.
-Chris
