Gauges for a high compression setup???
Old May 23, 2002 | 01:13 PM
Pinhead's Avatar
New User
Default Gauges for a high compression setup???
Hey, I was wondering if there were any gauges that would help me out, in case of any problems in my motor, for example maybe engine temp...and a website that has them for cheap would be helpful too
Old May 23, 2002 | 01:30 PM
norice's Avatar
Default Re: Gauges for a high compression setup??? (Pinhead)
Autometer make some reasonably priced gauges. Oil and coolant temperature, oil pressure, and fuel pressure gauges should do the trick.
Do a search too. This has been discussed recently.
Old May 23, 2002 | 02:15 PM
Tbone's Avatar
Fuel pressure gauge is a wise investment on a high cr motor. I have a fuel press,oil press,a/f. All greddy.
Old May 23, 2002 | 02:35 PM
EagleR's Avatar
Default Re: Gauges for a high compression setup??? (Tbone)
Also for a high CR an Exhaust temp guage. These are acurate unlike Autometer A/F guages and will tell you if you are running rich or lean as well.
Old May 23, 2002 | 03:21 PM
AllMotorITR's Avatar
New User
Default Re: Gauges for a high compression setup??? (EagleR)
Defi makes tyte *** gauges!!!! "ITRinEJ1" can get them for you too...
Old May 23, 2002 | 03:39 PM
FAST94GSR's Avatar
New User
Default Re: Gauges for a high compression setup??? (1 FAST R)
oil pressure without a doubt take it from me. Fuel pressure leave in the engine bay. You really don't need anymore than that.
Old May 23, 2002 | 05:30 PM
Tbone's Avatar
Default Re: Gauges for a high compression setup??? (FAST94GSR)
I diasagree If a high compression motor leans out because your fuel pump is intermittent and you dont catch it BOOM You dont have to get a mechanical gauge(even though its more accurate), you can get one with a sending unit like my greddy one has.
Old May 27, 2002 | 09:11 AM
Pinhead's Avatar
New User
anybody else? should oil pressure and EGT do the trick??
[Modified by Pinhead, 1:12 PM 5/27/2002]
Old May 27, 2002 | 09:20 AM
EagleR's Avatar
If your only runnin teo than yeah. If not get a Fuel pres, oil and coolant temp...those couple of extra hundred on guages can save the thousands later, ya know what I mean
Old May 27, 2002 | 01:54 PM
t's Avatar
t
Maybe a J&S safeguard.
Old May 27, 2002 | 02:17 PM
Tony the Tiger's Avatar
Default Re: Gauges for a high compression setup??? (t)
Oil pressure, J&S and EGT (or a decent AF meter).
Old May 27, 2002 | 02:22 PM
Pinhead's Avatar
New User
Default Re: Gauges for a high compression setup??? (Tony the Tiger)
is J&S nescessary with 12:1 compression tuning with hondata?
Old May 27, 2002 | 02:39 PM
FSTASNTZ's Avatar
Not if tuned right. 12.4:1 compression here with 93 octane on the street...
Jason
Old May 27, 2002 | 02:40 PM
Pinhead's Avatar
New User
Default Re: Gauges for a high compression setup??? (FSTASNTZ)
well, Mike K is tuning it so it should be ok
Old May 27, 2002 | 02:56 PM
spoonek4's Avatar
STTTTTTTTTACK that's the best of the best out there. Anyway....just kidding LOL....the price of a STACK is too hardcore for most of us.
Defi, APEXi, HKS are all reliable on gauges. For a high CR motor I will go for A/F mixture, coolant & oil temp, and oil pressure gauges. That's quite enough to monitor the motor's condition I think.
Old May 27, 2002 | 02:58 PM
Pinhead's Avatar
New User
Default Re: Gauges for a high compression setup??? (spoonek4)
well I need 2 1/16inch gauges, who makes those besides autometer? and which two would be the BEST....I think oil pressure and EGT should be enough...
[Modified by Pinhead, 7:10 PM 5/27/2002]
Old May 27, 2002 | 04:54 PM
Pinhead's Avatar
New User
anybody...
Old May 27, 2002 | 05:01 PM
New User
Defi I think....
Old May 28, 2002 | 01:48 AM
Midwestrider's Avatar
get the 52mm gauges, and you will have to slightly dremel out the autometer pods (2-1/16)
4ghatch
Oct 22, 2007 12:47 PM
aleks77
Mar 29, 2007 02:39 AM
ekim952522000
Sep 28, 2006 05:13 AM
stdefhatch
Mar 20, 2006 03:18 PM
