Engine Trouble PLEASE HELP
Old Nov 8, 2004 | 10:07 PM
bhornback10's Avatar
Default Engine Trouble PLEASE HELP
I have a 2000 R and it has been sputtering on me for the past couple of days. Only happens when I hit the gas. Thinking it might be a plug wire going bad but thats just a guess. Any suggestions? Thanks in advance.
Old Nov 8, 2004 | 10:19 PM
hYpE-R-29's Avatar
Default Re: Engine Trouble PLEASE HELP (bhornback10)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bhornback10 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 2000 R and it has been sputtering on me for the past couple of days. Only happens when I hit the gas. Thinking it might be a plug wire going bad but thats just a guess. Any suggestions? Thanks in advance.</TD></TR></TABLE>
sputtering??...need more detail bro....on freeway? in VTEC?...mileage on ur R??....ur past tune-up??
Old Nov 8, 2004 | 10:38 PM
Default Re: Engine Trouble PLEASE HELP (hYpE-R-29)
74K miles, comptech header, intake, and apexi exhaust. It does it in low rpms on the street only when I'm driving. It doesn't do anything at idle. Just checked the oil when I filled up on Sunday and it is fine. It loses power when it is sputtering and has sort of a jerky feeling to it.
Old Nov 8, 2004 | 10:46 PM
B2FiNiTY's Avatar
Change out your spark plugs, wires, distributer cap and rotor.
Old Nov 8, 2004 | 10:49 PM
hYpE-R-29's Avatar
Default Re: Engine Trouble PLEASE HELP (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Change out your spark plugs, wires, distributer cap and rotor. </TD></TR></TABLE>
yup!!! do a valve adjustment while ur add it and check timing....check ALL fluids ..u should be good to go
Old Nov 8, 2004 | 11:05 PM
Thanks for the help. I'll let you know what happens.
Old Nov 8, 2004 | 11:52 PM
Kicker773's Avatar
basically almost a complete tune up ... good luck keep us updated
Old Nov 9, 2004 | 01:29 AM
Slow_Em1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bhornback10 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 2000 R and it has been sputtering on me for the past couple of days. Only happens when I hit the gas. Thinking it might be a plug wire going bad but thats just a guess. Any suggestions? Thanks in advance.</TD></TR></TABLE> could be a number of things...injector, plug, plug wire, ignition timing, fuel pressure, fuel filter, compression rings....could be thouasands of things...those are just the most obvious
good luck
Old Nov 9, 2004 | 07:13 AM
Bbasso's Avatar
My car had the sputtering then I checked the plugs to find out the bad news...
https://honda-tech.com/zerothread?id=1010549
Old Nov 9, 2004 | 07:38 AM
esponet's Avatar
whens the list time you serviced it? could be a bad plug wires or cap
Old Nov 9, 2004 | 07:58 AM
MattD@Stoptech's Avatar
Check engine light on?
MyNamesMatt
Apr 28, 2014 09:55 AM
weirdone86
Dec 8, 2006 07:20 AM
Lsos
Mar 2, 2006 05:55 AM
quik1
Dec 19, 2003 03:32 PM
Dorikamu
Sep 23, 2002 06:21 AM
