engine throwing codes
Old Sep 22, 2007 | 02:16 PM
rpc08's Avatar
Default Engine code P1457 how to fix?
does anyone know how to fix code P0138 Secondary Heated Oxygen Sensor (Secondary HO2S) Circuit High Voltage
and P1457 Evaporative Emissions (EVAP) Control System Leakage (EVAP Canister System)
Modified by nos86 at 12:41 PM 9/24/2007
Old Sep 22, 2007 | 02:25 PM
Casey's Avatar
Default Re: engine throwing codes (nos86)
are you catching them?
Old Sep 22, 2007 | 05:49 PM
rpc08's Avatar
Default Re: engine throwing codes (Casey)
no not at all
Old Sep 22, 2007 | 06:34 PM
typeR#0427's Avatar
i am also getting the P1457 code, i checked all the evap stuff and nothing seemed out of the ordinary.
is the sensor on top of the canister bad?
Old Sep 22, 2007 | 07:37 PM
BMaDOHC's Avatar
Default Re: engine throwing codes (typeR#0427)
jump 12 volts to the canister shut valve, on the canister, and see if it clicks, if it doesn't it might be stuck and needing a new one.
replace your o2
Old Sep 22, 2007 | 10:58 PM
rpc08's Avatar
Default Re: engine throwing codes (BMaDOHC)
okay i know this sounds stupid but how do you do that?
Old Sep 23, 2007 | 06:23 AM
BMaDOHC's Avatar
the canister is on your firewall, its got a shut valve on the top of it. disconnect the connector and run two wires from your battery right beside the canister. positive on one side, neg on the other. presto!
Old Sep 23, 2007 | 08:14 AM
rpc08's Avatar
pics perhaps
stackz
May 2, 2009 03:28 PM
St3v3
Feb 4, 2009 07:26 AM
5po0n_Dc2
Feb 24, 2005 04:13 AM
2camsaam
14
Sep 24, 2003 01:20 PM
wm5holla
Jul 10, 2003 09:40 AM
