Engine Start up problem.
Old Jan 25, 2009 | 06:07 PM
Chim64's Avatar
Default Engine Start up problem.
I have a 94 vtec Honda Del sol with a gsr bottem end and a type R head. I jsut had it rebuilt around november. Since them i have had horrible starting problems in the cold. The car starts for a second then instantly dies out. Then after 4 to 5 times it will stay on but with really low idle like 100 or less rpm. If i try to rev after i finally get it started it will die. I will then proceed to leave it running for about 30 to 40 min. I will come back and the engine will still be a low idle at like 100-200. Then i will start to drive and the car will finally warm up about 30 min into driving. I have a check engine light on for thIAC (EACV) idle air control valve and one for the water temp sensor. But after looking up many different searches about this problem it seems like alot of people are saying it has to do with fuel injectors. Any sort of help would work. I am either about to sell this car and give up on honda for a while or keep it and fix the car up.
I also have a weird bounce in the front and the car rides horrible now since the rebuild. I put new axles and front struts in around the same time and since then i have horrible wheel ho( i think) which permits me form peeling out. and causes alot of problems driving the car in the winter.
Old Jan 25, 2009 | 06:31 PM
joeyrtype2k's Avatar
Default Re: Engine Start up problem.
thats why it idles so low the screen could be cloged or just shot replace it its not the injectors!
Old Jan 25, 2009 | 06:41 PM
Chim64's Avatar
Do you know where i can get a iacv for my car. also i jsut notice i have a leak by the gasket where i just replaced the gasket in november. Idk if its teh vtec sol or if hte water temp sensor is there.
dgcarmack
Jan 12, 2009 03:05 PM
sepetinswenze
Sep 5, 2008 09:55 PM
Thanks knightsport!
Jan 2, 2006 05:58 AM
2000civicsi
10
Oct 26, 2005 04:05 PM
Freshsho
May 26, 2005 11:46 AM
