Engine problems with the itr
Old Nov 4, 2006 | 11:38 AM
sleeper_teg's Avatar
Default Engine problems with the itr
hey
my teg started runnin real bad yesterday. it runs fine at idle but when i put it in gear and start driving, it starts acting up real bad. the tach jumps all over the place even though the engine speed might be something completely different. the engine also jumps and trys to stall real bad too. at first i thought it might be a fuel problem cause we just saw our first freezing temps a couple days ago, and i thought i might have some crappy fuel, even though i run 93, but that doesnt explain why the tach was all over the place
on monday i took the car to a respectable shop which has worked on and raced honda's for many years, and i got a vafc-2 installed. i replaced the exhaust and got the car tuned and it gained just over 21 whp. they finished everything tuesday. wed and thurs i didnt have any problems with the car, but then yesterday it started doing this.
so im wondering what you guys think it is. my guess is its something with the vafc but could it also be something with the temperature as well, considering for the first couple days....i didnt have any problems?
Old Nov 4, 2006 | 11:47 AM
92TypeR's Avatar
FSAE
Default Re: Engine problems with the itr (sleeper_teg)
Loose connection most likely. Double check the VAFC wireing and also around the MAP sensor.
Old Nov 4, 2006 | 01:14 PM
Default Re: Engine problems with the itr (92TypeR)
gosh if i can find the map sensor i'll certainly try
Old Nov 4, 2006 | 01:28 PM
allyourapex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeper_teg &raquo;</TD></TR><TR><TD CLASS="quote">gosh if i can find the map sensor i'll certainly try</TD></TR></TABLE>
On top of the throttle body.
Old Nov 4, 2006 | 03:40 PM
azteggi's Avatar
Default Re: Engine problems with the itr (allyourapex)
yo man. i had the same problem last week. it was a ground problem. when i drove the car it was fine. but with movement. it lost connection sometimes. and cause my rpms to go crazy.. hope this helps
Andrei330
Aug 25, 2016 04:32 AM
CaliforniaSnow
Feb 12, 2014 08:00 PM
AtownAccord
Oct 11, 2004 03:21 PM
crxtreme27
May 5, 2003 07:15 AM
schwett
Jan 21, 2002 07:14 PM
