engine problems with code but can't
Old Jun 18, 2001 | 03:28 PM
b18c5sol's Avatar
New User
Default engine problems with code but can't
When I start the car and the idle settles the check engine light comes on. I turned off the car, turn the key to the second position, jumper the plug and it won't show a code(none and the engine light won't come on at all). It's like it resets. I need some suggestions.
Also, While the engine is on and the check E Light is on, if you start to give it gas, it bogs for a spit sec. and then goes up like normal.
I'm clueless. If I could get the code it would send me in the right direction.
By the way........97 ITR motor in a 93 Del Sol using a GSR computer.
Old Jun 18, 2001 | 03:52 PM
KJ's Avatar
KJ
Default Re: engine problems with code but can't (b18c5sol)
I think the GS-R ECU may be the problem.
Old Jun 18, 2001 | 04:01 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: engine problems with code but can't (KJ)
Replace it with a computer from a VW Jetta. I'm sure it will be fine.
Old Jun 18, 2001 | 06:39 PM
sgT's Avatar
sgT
Default Re: engine problems with code but can't (nsxtasy)
if u turn the car off it will reset.
why dont you try checking the code while the engine is still running.
its as simple as that
Old Jun 18, 2001 | 06:47 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: engine problems with code but can't (sgT)
Most Honda ECU's DON'T reset when you turn the car off, once. They reset when you turn it on and off about 30 times or so.
As for the Jetta ECU, well...
Old Jun 18, 2001 | 06:57 PM
sgT's Avatar
sgT
on pre 96 computers, if the code isnt substantial enough, it will
disregard it once the ignition is turned off.
on pre 92 computers it forgets any code once the ignition is turned off.
If the code is important enough it will wait a certain number of driving
cycles before deleting it, it has nothing to do with how many times
you cycle power.
Old Jun 18, 2001 | 07:37 PM
nsxtasy's Avatar
H-T Order of Merit
Not true.
Take a look at the self-diagnostic procedures in the service manual for a (pre-92) 1991 NSX, pages 11-19 through 11-22 at http://www.nsxprime.com/FAQ/Referenc..._svcman/11.pdf You will see that you need to not only turn off the car, but also pull the clock fuse to reset the codes. (If the codes were reset by turning off the car, you wouldn't need to pull the clock fuse.)
Old Jun 19, 2001 | 02:14 PM
b18c5sol's Avatar
New User
Default A little more info about it...........
A little more info for you. Everything was fine until yesterday(It's been running over a year now with not one problem).
I did try to check the code with the engine running(engine light on)but it still didn't supply the flashes(giving the code number).
This is a 95 ECU
And from what I've been told and seen before, Steve is correct about the computer(OBD 1) reseting the check engine light if it's not significant.
250r king
Apr 17, 2010 10:08 PM
blaze.1
Sep 24, 2009 11:04 AM
BigMig
May 10, 2003 06:01 PM
wadafa
11
Oct 3, 2002 03:49 PM
