Engine problem
Old Mar 24, 2003 | 01:54 AM
Pompiuses's Avatar
Default Engine problem
The problem occurs when I go off the throttle when "in VTEC". Lets say I'm at 8000rpm on full throttle and I lift the accelerator half way up, the engine really start to jerk. If I'm driving continuosly (partial throttle) in VTEC the engine also start to jerk. Everything seems ok when I'm at full throttle or no throttle in VTEC.
The yellow checklamp on my dash (below the oil lamp) also comes on just about once a week. All I have to do is turn the engine off, wait for a minute and start it up again and it seems to be ok. Does this checklamp indicate eletrical errors?
My engine mods are:
Ractive ignition wires
Ractive air intake system
I suspect it might be the Ractive ignition wires, but the car have worked fine with them for about two months. Any ideas?
Old Mar 24, 2003 | 02:28 AM
rainmanEK's Avatar
big strong guy
Default Re: Engine problem (Pompiuses)
Seems Weird, But Try re-installing The oem Ignition Parts and see if problem Presist!
BTW....I have noticed at High RPM's My car to be jerky when Releasing the Gas!
Eric
Old Mar 24, 2003 | 02:57 AM
00MRSi's Avatar
Default Re: Engine problem (rainmanEK)
Get rid of that RACTIVE crap you're using. It's garbage..
Old Mar 24, 2003 | 03:27 AM
Pompiuses's Avatar
i'll do
Old Mar 27, 2003 | 11:27 AM
Pompiuses's Avatar
ok removed the ractive ignition wires and put the stock back on. Didn't get better
Took the car to a friend og mine who is a honda mecanic and tried to read the errorcodes from the computer. We couldn't quite figure it out the codes But we think the it indicated error with MAP sensor. Does that sound right??
[Modified by Pompiuses, 8:28 PM 3/27/2003]
Old Mar 27, 2003 | 04:29 PM
SRDrag's Avatar
could be a simple fuel problem
Old Apr 4, 2003 | 10:57 AM
Pompiuses's Avatar
Default Re: Engine problem (RIGHTHANDDRIVEITR)
Finally figured out how to read the ECU error codes. The code said "MAP sensor high voltage". Measured the voltage from ECU to the MAP sensor and it was fine. Changed the MAP sensor and voila' , the car ran smooth as silk. The MAP (manifold air pressure) sensor thought it was receving more voltage than it did, so it gave the engine too much fuel and too little air.
Luckily for me I got a used MAP sensor from a 1998 CR-V 2.0i. It turned out that a new one cost 700$ (in Norway). I just paid 60$ for the used one with 125000km on it. Couldn't be happier
[Modified by Pompiuses, 7:58 PM 4/4/2003]
Old Apr 4, 2003 | 02:42 PM
itr537's Avatar
not to be rude....but ractive is junk....get rid of it all....
Old Apr 4, 2003 | 02:55 PM
itr1244's Avatar
Default Re: Engine problem (itr537)
rative. r u kidding?
check the connection and make sure you have good level of oil
and also do a compression test .
i dont know. but good luck
Old Apr 4, 2003 | 03:09 PM
EVIL CETANE's Avatar
If you type the word "Reactive" and it is not immediately followed by "sucks" or are talking about Chemicals. I will fly to Norway and kick your ***.
You are an ITR owner with that comes the responsibility to research anything you buy for at least a month before purchases, Or just do What Mike M and SGT tell you to.
[Modified by EVIL CETANE, 4:10 PM 4/4/2003]
Mohamad
Honda S2000
11
Aug 27, 2008 02:21 PM
bbLUDE
Mar 22, 2008 09:46 AM
CraigA
Nov 29, 2006 04:00 PM
jerrywidening
Sep 26, 2004 11:24 AM
undrcroft
Sep 22, 2004 07:40 AM
