engine knock upon startup
Old Feb 10, 2004 | 10:11 PM
an2ny888's Avatar
Default engine knock upon startup
when i start the car it goes whir whir whir then KNOCK! its a stock b18c-r , only mods are b16b cams. it only knocks once upon startup, but that sound is like the kiss of death to me, and i want to get rid of it at all costs
Old Feb 10, 2004 | 11:03 PM
yellow blur's Avatar
Default Re: engine knock upon startup (an2ny888)
In the mornings during cold starts, after it fires up, I hear this knocking really fast, sounds like its piston slap or something. I'm thinking it's the same thing you are experiencing. Either that or my motor is about to blow!
Not sure what to make of it, my car still runs strong though.
Ed
Old Feb 10, 2004 | 11:04 PM
Bbasso's Avatar
hows the oil, old?
Old Feb 11, 2004 | 01:42 AM
an2ny888's Avatar
Default Re: engine knock upon startup (Bbasso)
just changed the oil. my knock only happens when the car is already warmed up and i need to restart it. doesnt knock when its cold started. and my knock is just one big knock when the engine catches, it doesnt knock after that
Old Feb 11, 2004 | 04:11 AM
RTW DC2R's Avatar
I get the same thing in my beater occassionally. Usually only on very cold morning start ups, but sometimes when its not so cold. I was told it was a bad sign but its been doing it for about a year and the motor runs fine otherwise so I never worried about it. Plus its on my beater so I dont really care.
Old Feb 11, 2004 | 05:02 AM
Bbasso's Avatar
How many miles on the motor?
Old Feb 11, 2004 | 05:54 AM
vtec.dc2's Avatar
are you running the right ecu, fuel pressure, ignition timing, maybe spark plugs.
Old Feb 11, 2004 | 06:01 AM
sil's Avatar
sil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 &raquo;</TD></TR><TR><TD CLASS="quote">just changed the oil. my knock only happens when the car is already warmed up and i need to restart it. doesnt knock when its cold started. and my knock is just one big knock when the engine catches, it doesnt knock after that</TD></TR></TABLE>
are you using a different oil filter?
Old Feb 11, 2004 | 09:08 AM
magic hat #9's Avatar
Default Re: engine knock upon startup (sil)
spark plug #3's electrode broke off and my motor developed a signicant "knock" that would noticeably shake the car (no related noise). i replaced the plug and problem solved.
Old Feb 11, 2004 | 03:54 PM
an2ny888's Avatar
Default Re: engine knock upon startup (magic hat #9)
m using honda oil filter, checked the spark plugs and timing, everything was ok. using the stock p73 ecu. only thing i havent checked is the fuel pressure
d17a1n00b
Honda Civic (2001 - 2005)
Oct 2, 2009 08:58 AM
Pompiuses
Mar 14, 2006 11:13 PM
Brand
Aug 10, 2004 02:29 AM
[626]95-GSR
Aug 21, 2003 05:33 AM
