Electrical Issue?
Old Feb 12, 2007 | 06:47 PM
Spoon ITR's Avatar
Default Electrical Issue?
I got in my car tonight and my CD was ejected like the battery died. I started the car no problems. No trouble turning on, all lights were bright, heat was working correctly, and the car had full power. The car asked for the radio code and the clock was out of wack so I fixed it and left.
About 25 minutes later I was driving down a back road and turned on my high beams and I felt the car jump and the CD skipped. That is the only other thing that happened the entire night besides stated in the first paragraph. Any ideas as to what it could be?
The car has....
An Optima yellow top battery
6000k HIDS
The only thing I can think of is the HID power wire is run right from the battery and is pulling alot of power out of the battery. Or a bad HID ground is messing with the entire car?
Old Feb 12, 2007 | 06:51 PM
Kavehman's Avatar
Clean the battery terminals, and check all of your engine bay grounds. Sounds like you have a bad ground, or a short somewhere.
Check any aftermarket wiring you have for kinks or anything like that.
Old Feb 12, 2007 | 06:54 PM
jetydosa's Avatar
25 Year Member
Default Re: Electrical Issue? (RTW CW ITR)
Check the ground to the chassis near the battery (make sure it is VERY tight). Mine was loose awhile back and my radio would randomly shut off and give me the CODE light. Not quite the same as your issue but Id check it at least.
Old Feb 13, 2007 | 11:20 AM
mstewar's Avatar
Default Re: Electrical Issue? (jetydosa)
yeah.. sounds like a grounding issue, probably from the HIDs, but I'd check them all.
Old Feb 13, 2007 | 11:21 AM
Doostur's Avatar
I say bad ground somewhere.
Old Feb 13, 2007 | 12:20 PM
andyt's Avatar
On my yellow top IIRC the base of the posts was fatter, or had a lip or something, and my terminals didnt go down as far, and occasionally I would hit a bump and the neg terminal would hit the hood and my electrical system would freak out for a moment. I had some "weird" electrical problems and after the fact I realized it was the yellow tops way of telling me it was dying. How long have you had the battery?
Old Feb 13, 2007 | 12:34 PM
sheekdude's Avatar
Default Re: Electrical Issue? (andyt)
The same thing happened to my civic w/aftermarket hids. I just took them out and that solved the problem.
Old Feb 13, 2007 | 01:58 PM
Spoon ITR's Avatar
Default Re: Electrical Issue? (sheekdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andyt &raquo;</TD></TR><TR><TD CLASS="quote">On my yellow top IIRC the base of the posts was fatter, or had a lip or something, and my terminals didnt go down as far, and occasionally I would hit a bump and the neg terminal would hit the hood and my electrical system would freak out for a moment. I had some "weird" electrical problems and after the fact I realized it was the yellow tops way of telling me it was dying. How long have you had the battery?</TD></TR></TABLE>
I'm not really sure, it was in the car when I bought it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheekdude &raquo;</TD></TR><TR><TD CLASS="quote">The same thing happened to my civic w/aftermarket hids. I just took them out and that solved the problem.</TD></TR></TABLE>
I had HID's in my old gsr for over a year and I never had any problem.
The car was fine all day today and I didn't check any connections it was to cold
JDMSTATUS425
Jul 13, 2008 02:44 PM
sTill JDM
May 19, 2007 07:38 PM
notguilty411
Audio / Security / Video
Nov 8, 2005 08:43 PM
blackie
10
Jul 22, 2005 03:44 PM
chad174
11
Apr 18, 2003 09:40 AM
