Dyno'ed the K20A Swap
![Default](https://honda-tech.com/forums/images/icons/icon1.gif)
Thought I'd keep you guys updated, I'm gonna x-post this in a couple other forums..
![](http://www.truerace.com/dyno/DSC00661.jpg)
![](http://www.truerace.com/dyno/DSC00662.jpg)
Big Images: http://www.truerace.com/dyno/Orig
What I expected, can't wait till the new header so it wont CHOKE AND DIE up top like it's doing...
Oh yeah, isn't that the nicest tq. curve you've ever seen![](https://honda-tech.com/forums/images/smilies/emsmilep.gif)
Mods:
STOCK MOTOR
STOCK ECU
STOCK Fuel Pressure
$5 autozone Filter on stock arm
STOCK TSX Header
2.5" Exhaust w/ Cat and chambered muffler![](https://honda-tech.com/forums/images/smilies/emsad.gif)
CEL: No REAR O2 Sensor hooked up, I don't think this will rob power, but some people tell me otherwise
Mods:
STOCK MOTOR
STOCK ECU
STOCK Fuel Pressure
STOCK TSX Header
Impressive, especially considering that its still a stock motor...
Good luck on the build-up and be sure to post more numbers when you get your exhuast done.
![](https://honda-tech.com/forums/images/smilies/emthup.gif)
not bad on stock everything.. Now its time to bring on the MODS... The rear 02 sensor is for a OBDII vehicle to make sure the cat and emissions system is working correctly.. Shouldn't see lots of power loss unless the car is running and/or lean..
Kevin
Kevin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">Exactly which header are you going with.</TD></TR></TABLE>
TrueRace Engineering 4-1 Long tube header...aka my own design...to shamelessly plug it'll be using a REAL merge collector, the prototype wont have steps but the final deisgn should. IM me if you want details
RTW - It's a JDM CTR motor which is exactly the same as a DC5R motor![](https://honda-tech.com/forums/images/smilies/emwink.gif)
Wanted - Yeah I knew what the purpose was and I don't think it robs power but K20eg says it "takes away a good amount of horsepower", but I think the dyno proves it doesn't b/c it makes the power it should 184 whp = ~218ish Crank
Mods comming this week-ish:
TrueRace 4-1 Header - then dyno
TrueRace Velocity intake
Hondata K-pro
New exhuast - Then dyno
I didn't want to mod it until I had a baseline to work with...
Modified by JoesTypeS at 8:53 PM 5/24/2004
Hondata K-pro
considering the tq doesnt drop off till 7.5k rpm thats pretty good.
im sure a header and other stuff will bump up the whole curve though, and keep the tq flat till 8k or higher
![](https://honda-tech.com/forums/images/smilies/emsmile.gif)
The numbers are nice, but tell everyone how it feels driving!!! The K20 in R spec is absolutely fabulous. It pulls hard everywhere in the powerband. With just the bolt-ons on my R, it transformed the car even more. JoeTypeS, just wait it gets so much better, without even opening up the engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC5RK20A »</TD></TR><TR><TD CLASS="quote">The numbers are nice, but tell everyone how it feels driving!!! The K20 in R spec is absolutely fabulous. It pulls hard everywhere in the powerband. With just the bolt-ons on my R, it transformed the car even more. JoeTypeS, just wait it gets so much better, without even opening up the engine.</TD></TR></TABLE>
Oh I know, and I can't wait...I'm really excited about our header design, I think everyone will like it (and esp like the quality)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAFA »</TD></TR><TR><TD CLASS="quote">Hytech it!</TD></TR></TABLE>
NO
NO
Very very nice... It would be really interesting to see the effect of the Hondata K pro alone on that setup... Maybe 200 WHP? And that is still with a restrictive header....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nikos »</TD></TR><TR><TD CLASS="quote">Very very nice... It would be really interesting to see the effect of the Hondata K pro alone on that setup... Maybe 200 WHP? And that is still with a restrictive header....</TD></TR></TABLE>
yeah I know I'm very torn, hondata it and tune then do a before after w/ header or put the header on the stock ECU to see the difference...I think choice 2 will lead to less drama, but who knows...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoesTypeS »</TD></TR><TR><TD CLASS="quote">yeah I know I'm very torn, hondata it and tune then do a before after w/ header or put the header on the stock ECU to see the difference...I think choice 2 will lead to less drama, but who knows...</TD></TR></TABLE>
Sounds like everything is going good.
You should post pics of the header when it is done
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon V »</TD></TR><TR><TD CLASS="quote">
Oh don't worry I will
impressive tq curve! wow!
cant wait to see how it responds to mods and tuning.... thanks for doing a baseline too, good thinking
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by owen_the_soyboy »</TD></TR><TR><TD CLASS="quote">impressive tq curve! wow!
You gotta come to a WNY-SCCA event so I can run D-Mod w/ someone else
