Dumb Question...
Old Jul 9, 2001 | 08:46 PM
Type Goch's Avatar
New User
Default Dumb Question...
i always get mixed up, whats the difference between understeer and oversteer?
Old Jul 9, 2001 | 08:49 PM
arren123's Avatar
Default Re: Dumb Question... (Type Goch)
Real short:
When your oversteering, your butt is flying out trying to swap ends. When understeering your car won't turn anymore and will plow forward.
Old Jul 9, 2001 | 08:50 PM
Chris's Avatar
UNDER steer is when the front keeps going straight when you turn.
OVER steer is when there is too much rotation, and the tail slides out.
Old Jul 9, 2001 | 08:51 PM
Type Goch's Avatar
New User
Default Re: Dumb Question... (Chris)
thanx guys!
Old Jul 9, 2001 | 08:57 PM
Pistonhead's Avatar
New User
Understeer involves front end traction, or rather, lack of or process of losing it. Called "push" sometimes. The car seems to not steer and much as you want, due to extreme front tire slip angles (steering input relative to car's response. Type Rs mainly understeer but in upper limits the rear will slide out slowly (light oversteer).
Oversteer involves rear end traction, or rather, lack of or process of losing it. Called "loose" sometimes. The rear end is rotating much more than you intended with the steering. Older Porsches, Vipers, Z06s put massive power to the rear and when not controlled expertly and delicately during cornering, break loose the rear for obvious reasons.
Ben850
Honda Civic (2006 - 2015)
11
Aug 20, 2009 07:27 AM
RAB
Jun 23, 2003 05:51 AM
Driven
May 4, 2003 06:42 AM
