Drivetrain slack...
Old Nov 5, 2003 | 10:01 AM
AssPenny's Avatar
Default Drive train slack/lash
As I was driving home in rush hour traffic last night and I noticed that my car has alot of slack in it. What I mean by slack, is every time i let off the gas or get on the gas the car tends to surge and shake a little. I've always noticed this in first gear, and just chalked it up to the ATS fd and the shortness of first gear. But lately, mostly last night, I noticed that I have it in all the gears and most notible in 3rd. Is this caused by something in the tranny, ie gear lash, or is it caused by the sprung clutch (springs getting weak)? Could it be the motor mounts going out also or is this a normal thing and I've just finaly noticed it?
Old Nov 5, 2003 | 10:05 AM
thk's Avatar
thk
Members Only
Default Re: Drive train slack/lash (AssPenny)
I noticed it when the car was stock. After several thousand miles and some bouts with wheel hop, it became noticable. It did become somewhat reduced after installing two of the 3 motor mount inserts.
I'm wondering what is causing this myself. Mounts? Clutch disc springs? I'm sort of ruling out disc springs since the springs were fine/intact when I got the 4.785 FD installed.
Old Nov 5, 2003 | 10:06 AM
ZygSpeed's Avatar
My first guess would be motormounts.
Are they still stock? Maybe one or mor have finally succumbed.
Old Nov 5, 2003 | 10:10 AM
AssPenny's Avatar
Default Re: Drive train slack/lash (zygspeed)
Yeah they are stock with inserts. I'm thinking of picking up some jim fabs soon though, hopefully that'll fix the problem and solve this mystery.
Old Nov 5, 2003 | 10:25 AM
Chris N's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny &raquo;</TD></TR><TR><TD CLASS="quote">Yeah they are stock with inserts. I'm thinking of picking up some jim fabs soon though, hopefully that'll fix the problem and solve this mystery.</TD></TR></TABLE>
I have the same issue. It seems to have become more pronounced as the miles rack up.
Old Nov 5, 2003 | 12:10 PM
typer_801's Avatar
Default Re: Drive train slack/lash (Chris N)
Check the rear tranny mount (on the firewall). I had the same issue and when I removed and replaced it with my Mugen mounts I found it had a crack in in nearly the full length of the mount. The rest showed normal wear (at ~60K) but the rear was definitely broken and in need of replacement.
Old Nov 5, 2003 | 12:19 PM
Champ R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N &raquo;</TD></TR><TR><TD CLASS="quote">
I have the same issue. It seems to have become more pronounced as the miles rack up.</TD></TR></TABLE>
Same here.
Old Nov 5, 2003 | 12:49 PM
AssPenny's Avatar
Default Re: Drive train slack/lash (Champ R)
Ok, well who makes a good rear mount?
I know jim fab makes some, but thouse are for the front 2 lower mounts.
Old Nov 5, 2003 | 02:18 PM
Big Phat R's Avatar
I'm sure some of it is due to the sprung clutch - how old is yours?
Old Nov 5, 2003 | 02:24 PM
Wai's Avatar
Wai
ProFunction/GT Motoring
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny &raquo;</TD></TR><TR><TD CLASS="quote">Ok, well who makes a good rear mount?
I know jim fab makes some, but thouse are for the front 2 lower mounts.</TD></TR></TABLE>
Hey John, how many miles you have on ur car, and clutch?
&lt;--- who has no constructive opinion in this thread. Just want to post and call him John.
Old Nov 5, 2003 | 02:29 PM
euclid's Avatar
Default Re: Drive train slack/lash (Big Phat R)
it's not totally the mounts. i have hasport solid mounts for the rear tranny and both upper mounts... then the jimfab lower torque mounts too, although i am just runnning the tranny side at the moment, i still get that lash. i think it is the clutch as well, everyone praises the stock itr clutch so much but i think it is a weak link, it is too soft.
i was orginally thinking it was the lsd getting older, could that be part of the problem too?
Old Nov 5, 2003 | 10:26 PM
Spike2's Avatar
I would like to know as well. Any other ideas from anyone?
Old Nov 6, 2003 | 06:11 AM
ILUVTEC's Avatar
Default Re: Drive train slack/lash (Spike2)
Craig, I just put the 2 lower Jimfab mounts and 3 upper HAsport mounts in my EG hatch, and the motor does not move at all, very nice and tight, and not too rough at all. Try this first. Of course, just the rear and maybe the two lower torque mounts will probably do for your application.
And you can bring the hood to burn at Marc's next party, but I'll be bringing a lot of crap from my totalled GSR, they will no lack of crap to lite on FIRE
Later, Clay
Old Nov 6, 2003 | 07:08 AM
AssPenny's Avatar
Default Re: Drive train slack/lash (ILUVTEC)
What were the part numbers for the upper and rear mounts? I went to hasports web site, but they have about 10 different mounts listed for a 94-01 integra.
Old Nov 6, 2003 | 08:15 AM
Tweakmeister's Avatar
maybe I'm feeling a different thing, but I'm adding urethane replacements to my shock top mounts (ie almost a spherical pillowball feeling)
Old Nov 6, 2003 | 06:39 PM
euclid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny &raquo;</TD></TR><TR><TD CLASS="quote">What were the part numbers for the upper and rear mounts? I went to hasports web site, but they have about 10 different mounts listed for a 94-01 integra.</TD></TR></TABLE>
DCSTK is the part # for the set of 3 mounts...be warned, these are stiff and i just told you that they will not completley solve this drivetrain lash, i think it is something else causing it.
Old Nov 7, 2003 | 05:06 AM
AssPenny's Avatar
Default Re: Drive train slack/lash (euclid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by euclid &raquo;</TD></TR><TR><TD CLASS="quote">DCSTK is the part # for the set of 3 mounts...be warned, these are stiff and i just told you that they will not completley solve this drivetrain lash, i think it is something else causing it.</TD></TR></TABLE>
Thanks, I'll let you all know how it works out. I've got to do some work on my car this weekend so i'll **** around with the drive line and see what I can come up with.
Old Nov 19, 2003 | 04:10 PM
Black R's Avatar
25 Year Member
.....I put some MORE motor mount inserts in today, and it cured my drivetrain slack/ lash problem.
Here's the thread:
https://honda-tech.com/zerothread?id=680862
Old Nov 19, 2003 | 04:32 PM
ZygSpeed's Avatar
Default Re: Drive train slack/lash (Black R)
Thanks for the info, my motor still moves around more than I'd like.
Don't know if it's the Azenis or not, but after switching back to them from my ~2 year old A032R's I got a BUNCH of wheel hop in the wet the other day (which I hadn't seen since putting in the ES inserts).
Old Nov 22, 2003 | 02:07 AM
euclid's Avatar
if anyone wants a set of hasport billit mounts or jimfab lower torque mounts i am selling mine, i am starting another project and alot of parts i am running now need to be sold. these mounts are only 2 months old.
both sets are solid uerethane, both street hardness, hasport kit includes the 2 upper and rear tranny mount, jimfab includes the 2 lower torque mounts. pm me
Old Dec 23, 2003 | 06:42 PM
Asahi's Avatar
I discussed this with Craig the other day. I have the exact same problems. Let me share what I found.
Old Dec 23, 2003 | 06:45 PM
Dave-ROR's Avatar
Default Re: Drive train slack/lash (Asahi)
HOLY HUGE PICS BATMAN.
Old Dec 24, 2003 | 01:46 AM
Black R's Avatar
25 Year Member
which mount is this?
and what did you replace it with?
Old Dec 24, 2003 | 04:28 AM
Asahi's Avatar
sorry about the pic size, I wanted to show the detail.
This is the rear mount (the important mount). I have not yet repaired/replaced it. I plan to mix a custom polyurethane caled Flexane where I can control the hardness (Want it solid but don't want vibration). The mount will be solid but should be much softer than most Poly stuff.
http://www.devcon.com/devconfa...d=151
Softener
http://www.devcon.com/devconfa...d=153
Old Dec 24, 2003 | 05:47 AM
AssPenny's Avatar
Nice I'm glad to see you tracked down what seems might be the problem. Mine is getting worse and worse, but I do have a hasport rear mount coming soon. I did end up going with the message chair hardness btw.
