driver side window does not go down
Old Mar 15, 2008 | 03:40 PM
Demon R's Avatar
Default driver side window does not go down
is this something that can be fixed or do i need a new switch? Passenger side window on the driver side switch does work. And the passenger side switch works also.
Old Mar 15, 2008 | 04:37 PM
00-501itrspec's Avatar
Default Re: driver side window does not go down (Demon R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demon R &raquo;</TD></TR><TR><TD CLASS="quote">is this something that can be fixed or do i need a new switch? Passenger side window on the driver side switch does work. And the passenger side switch works also.</TD></TR></TABLE>
maybe it fell off the track , does the window motor make noise when you move the switch ?
Old Mar 15, 2008 | 04:38 PM
Erik95LS's Avatar
it could be the switch or the motor. Try putting 12v power and ground to the two wires into the motor and see if works. If it does, it's probably your switch; if not, it's more likely the motor.
Old Mar 15, 2008 | 04:44 PM
Doostur's Avatar
My old EK use to fall off the track all the time. Useless you kept it lubed on the corners, the friction would cause one end to pop out and then you had to take off the whole door panal etc. No bad experiences with the dc2 though. If you try to go up or down and do you hear a click and a little jolt then you know everything is working and its probably off track.
Old Mar 15, 2008 | 04:47 PM
Demon R's Avatar
Default Re: driver side window does not go down (00-501itrspec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00-501itrspec &raquo;</TD></TR><TR><TD CLASS="quote">
maybe it fell off the track , does the window motor make noise when you move the switch ?</TD></TR></TABLE>
No it doenst make any noise. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik95LS &raquo;</TD></TR><TR><TD CLASS="quote">it could be the switch or the motor. Try putting 12v power and ground to the two wires into the motor and see if works. If it does, it's probably your switch; if not, it's more likely the motor.</TD></TR></TABLE>
I have to try that out. thx
Old Mar 15, 2008 | 05:00 PM
cmdr430's Avatar
can our windows fall off the track?
just curious...... because I would have thought that they could not because of the window pin guide system, or whatever it is called......
to the op, it sounds like the switch to me.....
builthatch
Honda Civic (2006 - 2015)
May 29, 2012 09:38 AM
Bayhustle81
Aug 31, 2009 01:44 AM
spd18
Nov 9, 2003 01:57 PM
dskny
Mar 26, 2003 04:23 PM
