CTR trailing arms
Old Oct 26, 2008 | 03:45 PM
jdmnitemare's Avatar
From: west bay,grand cayman, w.bay, grand cayman,cayman islands
Default CTR trailing arms
here is my question....i have a actual real honda dc2 ITR 1996...i want to change from 4x114 to 5x114...but i wanna no if the CTR trailing arms are the same length...n would i need an alignment after the swap is done....plz help
Old Oct 26, 2008 | 03:48 PM
coolhandluke's Avatar
Default Re: CTR trailing arms (jdmnitemare)
Anytime you change parts of your suspension an alignment is always recommended. I don't have an answer for your main question.
Old Oct 26, 2008 | 03:53 PM
Default Re: CTR trailing arms (coolhandluke)
thanks anyway
Old Oct 26, 2008 | 04:14 PM
highroller54's Avatar
the trailing arms are the same, swap the wheel bearings, rotors and calipers over and you done with no alighnment. Or swap the whole thing and get a alighnment, when you do the front you will need one anyways.
Old Oct 26, 2008 | 04:16 PM
Default Re: CTR trailing arms (highroller54)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highroller54 &raquo;</TD></TR><TR><TD CLASS="quote">the trailing arms are the same, swap the wheel bearings, rotors and calipers over and you done with no alighnment. Or swap the whole thing and get a alighnment, when you do the front you will need one anyways.</TD></TR></TABLE>
The rear alignment of the vehicle affects the front end alignment.
Old Oct 26, 2008 | 04:22 PM
thanx guys 4 the help...very much appreciated
Old Oct 26, 2008 | 07:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coolhandluke &raquo;</TD></TR><TR><TD CLASS="quote">
The rear alignment of the vehicle affects the front end alignment. </TD></TR></TABLE>
I think you need to re-read what I wrote, of coarse I'm teraible at explaning things....that could be the problem, lol.
Old Oct 26, 2008 | 10:01 PM
Tight R's Avatar
everything in the rear is the same except for the lca
Old Oct 27, 2008 | 01:16 AM
sheekdude's Avatar
Default Re: (Tight R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tight R &raquo;</TD></TR><TR><TD CLASS="quote">everything in the rear is the same except for the lca</TD></TR></TABLE>
x2...
Old Dec 5, 2008 | 11:39 PM
aSilvrHaze's Avatar
so the 96 spec type r trailing arm spindle is the same length as the 98-01?
Old Dec 6, 2008 | 01:41 AM
BlueIntegraBoy's Avatar
Yes
Old Dec 6, 2008 | 06:41 AM
94rs-turbo's Avatar
Now thats real tech work! nice job guys
Old Dec 6, 2008 | 07:41 AM
Originally Posted by BlueIntegraBoy
Yes
x2!
TheWhiteHatchProject
Suspension & Brakes
Feb 11, 2007 06:07 PM
CMVTEC95
Feb 25, 2005 02:04 PM
90civichbsi
Jul 10, 2004 08:30 AM
deeksmooth
Dec 19, 2003 04:10 PM
Danger
May 26, 2003 07:13 AM
