CTR Piston installation.
Old Jul 18, 2001 | 02:27 AM
DC2#309's Avatar
New User
Default CTR Piston installation.
does the CTR piston goes in straight into B18C-R engine without any modification?
Old Jul 18, 2001 | 03:18 AM
6SPD_EK's Avatar
Default Re: CTR Piston installation. (DC2#309)
stock bore size yes, is this a daily driven car? what octane fuel will you be using, I would be very weary of putting these pistons in my car due to the very good possiblity of detonation!
Old Jul 18, 2001 | 03:29 AM
SuspectProduct's Avatar
New User
Yeah they will go right in. I just had a set installed in my ITR along with my Toda C's.
I would suggest a J&S Safeguard or some other type of knock sensor. The compression ratio with these pistons is somewhere in the 12.1:1 to 12.2:1 area.
I'm running 93 octane daily driven.
Old Jul 18, 2001 | 03:43 AM
TypeR509's Avatar
New User
DC2#309, how did u get a 13.89 qtr mile with only those mods??? how much power did the apexi power fc provide?
is this time on slicks?
Old Jul 18, 2001 | 05:04 AM
FAST94GSR's Avatar
New User
Default Re: CTR Piston installation. (SuspectProduct)
Did you not have to worry about piston to valve clearance issues or wristpin location? Are you telling me they bolt up, meaning i can slap some in and not worry bout anything??
Old Jul 18, 2001 | 02:22 PM
itr1236's Avatar
Default Re: CTR Piston installation. (FAST94GSR)
Somebody told me today that the CTR pistons only gave the type r 11.6:1, but you guys say it is in the 12's. Are you guys certain about this, and do you think that 12:1 compression can be tuned to use with pump gas??
Old Jul 18, 2001 | 02:28 PM
6SPD_EK's Avatar
Default Re: CTR Piston installation. (itr1236)
these guys are right in a b18c5 is right around 12.1:1 in a B18c1 its about 12.4:1 - pump gas maybe if its 93 or 94 octane
Old Jul 18, 2001 | 04:17 PM
DC2#309's Avatar
New User
Default Re: CTR Piston installation. (TUF2BT)
we in Australia gets 98 octane, so higher compression shouldnt be that matter.
just checkin if all the valve clearance and everything is allrite, and the car will be running powerFC, and powerFC has knock sensor.
TUF2BT, we spent like 12 hours in total tuning the car with powerFC up to a small little point in everypoint of the tuning, and that is the result you get if you spend good time with tuning.
I gained around 20kW at the wheels with powerFC. that is from pure stock.
Old Jul 18, 2001 | 04:25 PM
DC2#309's Avatar
New User
also, JDM 4-1 gives me all overall good performance and gained around 6kW from the last mod at the peak power.
Old Jul 18, 2001 | 06:09 PM
DC2#309's Avatar
New User
anyone with more tips?
Old Jul 18, 2001 | 06:12 PM
N1Spec's Avatar
New User
jacob, whatabout valve/piston clearance..... u are using Toda Spec C's remember.
Someone please clarify this..... will CTR pistons work with Toda Spec C?
Old Jul 18, 2001 | 06:36 PM
Mike M's Avatar
Founding Member
Default Re: CTR Piston installation. (N1 Spec)
Yes as long as you don't mill the head.
Old Jul 18, 2001 | 10:43 PM
DC2#309's Avatar
New User
Default Re: CTR Piston installation. (TypeRmsm)
no other head work will be done besides port and polish, camshaft, spring, & retainer.
Old Jul 19, 2001 | 04:54 PM
DC2#309's Avatar
New User
any other comment?
Old Jul 23, 2001 | 08:26 AM
New User
No worries at all about clearance. I have a stock head. No milling.
Wrist pins were not a problem.
I have an ITR. Should be the same as GSR as far as just putting them. No problems.
Old Jul 23, 2001 | 11:02 AM
VTEC4GS's Avatar
you just need to have the machinist fit the rods to the pistons, it does not install like stock, they need to be modifed.
Greg
Old Jul 23, 2001 | 11:08 AM
FAST94GSR's Avatar
New User
Default Re: CTR Piston installation. (vtec4gs)
gettin a new itr shortblock , i wonder if i should put new ctr pistons in. My head is milled 20 thousands. I think that would be way too high on pump gas.since I have a gsr head.
Old Jul 23, 2001 | 08:12 PM
2fcknfst's Avatar
I think the other thing yo have to be concerned with is the angle of the valves with the milled head in relation to the pistons...
I know the WISECO (Endyn) pistons have a slightly better angle (READ: Valve Friendly) than the CTR units. There has also been some development work into creating a better anti-knock design....
knuckk
Dec 19, 2007 06:07 AM
danthemang3
Jul 16, 2007 02:54 PM
guedo148
Apr 15, 2007 09:08 PM
paeaknoy
Apr 11, 2004 03:32 PM
mugenintegra16
Jun 9, 2002 05:49 PM
