Confusing....
Old May 20, 2002 | 08:59 PM
JDC2's Avatar
Default Confusing....
Ok i've heard that the JDM & USDM ITR exhaust piping are the same diameter. the only difference is the length of the cat? Then how come the JDM 4-1 doesn't fit USDM ITR without modification? Can anyone explain?
Old May 20, 2002 | 09:04 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Confusing.... (JDC2)
JDM header has a larger collector, therefore requires larger cat. Past that, you're on your own. I have no idea what the JDM cat outlet size is, nor the JDM b-pipe...
Old May 20, 2002 | 09:05 PM
B2FiNiTY's Avatar
Default Re: Confusing.... (itr009)
I'm guessing the JDM inlet is 2.5 but outlet is 2.25 the rest.
Old May 21, 2002 | 04:04 PM
t's Avatar
t
JDM b-pipe is longer, JDM cat is shorter, JDM header is same length as U.S. header
JDM header has a 2.5" opening to mate to the JDM cat
US header has a 2.25" opening to mate to the U.S. R/LS cat
Old May 21, 2002 | 04:21 PM
disordeR's Avatar
i believe.. from what i have heard, both inlet flanges on the b-pipe are 1-3/4".
Old May 21, 2002 | 04:26 PM
Asahi's Avatar
Default Re: Confusing.... (t)
JDM header much farther under the car than USDM header. Cat is shorter on JDM but I cannot guess what B-pipe is but with a longer header and a shorter cat I would think the JDM b-pipe would be shorter or equal to USDM.
Old May 22, 2002 | 04:56 AM
Dave-ROR's Avatar
Default Re: Confusing.... (Asahi)
JDM B-Pipe length == USDM 94-99 GS-R B-Pipe length.
Old May 22, 2002 | 08:40 PM
t's Avatar
t
NO.
Old May 22, 2002 | 08:57 PM
Mike M's Avatar
Founding Member
Default Re: Confusing.... (01_Yeller_ITR)
Right on the money
Just so everyone understands, were just talking length. Pipe size and design do differ from a GSR's
The JDM Header is about .75" longer than the USDM header
The JDM Cat is about 12" long
JDM ITR B Pipes (Just like USDM GSR B Pipes) are about 5" longer than a USDM ITR B pipe
Did I miss anything
Old May 22, 2002 | 08:59 PM
Chris's Avatar
Default Re: Confusing.... (TypeRmsm)
Isnt GSR B pipe crush bent, and R mandrel?
Old May 23, 2002 | 03:20 AM
Asahi's Avatar
NO.
Seems the people that sell the parts and make the cats to make the parts work on USDM cars disagree. Any reason you in particular you have this differing opinion than everyone else?
Old May 23, 2002 | 04:48 AM
Dave-ROR's Avatar
Default Re: Confusing.... (Chris)
Chris: Yes, which is why Mike said they differ in design
Trey: They are different lengths, like mike said the JDM is slightly longer, but like Dan's test pips, you CAN make it fit even if it's too long (ok, please don't take that out of context )
Old May 23, 2002 | 05:46 AM
DutchITR1689's Avatar
SMSP said USDM header is 2" OD.
The Euro header at least has a 2" flange. The JDM header is longer than the Euro header.
jdm_94
May 15, 2009 09:22 PM
ITR3189
Aug 1, 2007 09:13 PM
saber1
Jun 22, 2003 06:32 PM
2k1TypeR0610
Sep 28, 2001 08:16 AM
Toda Party
Sep 13, 2001 07:48 AM
