compression #'s
Old Oct 16, 2003 | 07:43 AM
cw98typer's Avatar
Default compression #'s
#1 260, #2 270 #3 265 #4 275. Getting leak down test tomorrow due to my car being fuct. Motor is pinging so bad so here we go w/ a rebuild. Eventhough i'm so broke .
Old Oct 16, 2003 | 07:48 AM
chad's Avatar
Moderator
Default Re: compression #'s (cw98typer)
those numbers are EXCELLENT....depending on what guage you are using!
Old Oct 16, 2003 | 07:49 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
those #s seem high. I thought 235 was "normal" Motor being "fuct" as you say would read lower #s, not higher. I could be wrong though and usually am.
Old Oct 16, 2003 | 07:50 AM
RTW DC2R's Avatar
I dont see anything wrong with those numbers. I think the general rule of thumb is no more than a 20lb variance between any 2 cylinders and you should be ok. pinging is caused when you are running lean. have you checked out your A/F?
Old Oct 16, 2003 | 07:54 AM
cw98typer's Avatar
Default Re: compression #'s (RTW DC2)
Fuct meaning i burn a quart of oil a week to a week and a half.
Old Oct 16, 2003 | 07:56 AM
RTW DC2R's Avatar
you are talking about oil and you had no mention of oil anywhere in the original post. if you want help you need to be more specific. do the leakdown and see what that tells you.
Old Oct 16, 2003 | 08:01 AM
cw98typer's Avatar
Default Re: (RTW DC2)
It was more of a post to show my #'S. After the leakdown test i'm sure ill be asking for help. The mech. that did the compression test told me to send the head out and get it machined and to fix whatever else they found wrong. The mech that is going to do the leakdown thinks the compression rings are fine but thinks the oil rings are done, as well as needing to send the head out. But tomorrow or by the weekend will know fo sho. **** sucz
Old Oct 16, 2003 | 08:04 AM
RTW DC2R's Avatar
Default Re: (cw98typer)
get a new mechanic bro. what the hell does this mean? "send the head out and get it machined and to fix <u>whatever else they found wrong</u>". dont you want to know what they supposedly found wrong? Or do you like just sending your head out for the hell of it.
Old Oct 16, 2003 | 08:26 AM
cw98typer's Avatar
Meaning get the valve guides and seals replaced. And once they have the head open if anything else is wrong????He said it's pinging so bad that he doesn't know what all is going to be fucked up once thay get the head open. Thats what he said. I'm getting the leakdown test done by a import mechanic who definately knows more than the guy who did the compression test and has worked on some of my friends cars. But any additional help would be great consiering i'm no mechanic. thanx
Old Oct 16, 2003 | 08:33 AM
RockstarJR's Avatar
Brent- told y0 *** to watch the oil y0. ****- quart a week- You must be not driving that thing as hard as i was. That thing is maen though. Wait till you rebuild her. Who is going to do the rebuild??? Let me know as i want to stop by and check it out.
Old Oct 16, 2003 | 08:35 AM
RockstarJR's Avatar
by the way the car has CTR pistons. When I compression tested it a little over a year ago she was around the same ballpark. The oil rings are done I can tell you that for sure. I wish I would have known marc back then, we could of had a battle to see who had the real "tanker"
Old Oct 16, 2003 | 09:33 AM
cw98typer's Avatar
Default Re: compression #'s (ITRChris)
As hard if not harder, can't get enough vtec. But will be w/out for a little while.
When i fo sho find out where i'm gettin it done def need come by and check it out. And let me hit vtec in your new R
Old Oct 16, 2003 | 09:38 AM
Default Re: (ITRChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRChris &raquo;</TD></TR><TR><TD CLASS="quote"> The oil rings are done I can tell you that for sure. I wish I would have known marc back then, we could of had a battle to see who had the real "tanker" </TD></TR></TABLE>
Nothing will ever outdo 3 quarts per gas tank
And if the rings are done, it shouldn't have anything to do with the head. When D replaced my block, the head was fine other than a little poo on the valves.
soedopelike89
Dec 9, 2010 09:16 PM
Counterfeit169
Apr 1, 2010 11:46 AM
HoUTX98GSR
Jun 29, 2005 10:01 AM
blackeg
Mar 28, 2005 06:10 AM
FOrSfEd
Jun 1, 2004 09:02 AM
