Code 67 - Bad cat?
Old Apr 26, 2003 | 10:19 AM
ITR1071's Avatar
Default Code 67 - Bad cat?
I did a search and there was only one topic on a CR-V w/ 100,000 miles on it. I have a 2001 ITR with 50K and my light came on with a code 67. I recently had an issue with my car dying and the cause was the distributor housing. Is my cat bad? How at 50K? Should I replace with stock or aftermarket?
Old Apr 30, 2003 | 07:26 PM
D0HC's Avatar
Default Re: Code 67 - Bad cat? (KillaB18C5)
Check to see if you have exhaust leaks any where
Old Apr 30, 2003 | 09:31 PM
YelLowITR's Avatar
damn.. i'm pretty sure 50k on 01 car is a lot mileage, since u drive it a lot and maybe long distance also. Reset your battery and see if the light still comes up, if so, i guess it's just time to replace some new parts, aftermarket or oem both would work. gl.
Old Apr 30, 2003 | 11:58 PM
Nameless RB26's Avatar
Default Re: Code 67 - Bad cat? (D0HC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D0HC &raquo;</TD></TR><TR><TD CLASS="quote">Check to see if you have exhaust leaks any where</TD></TR></TABLE>
Old May 1, 2003 | 03:48 AM
Asahi's Avatar
Default Re: Code 67 - Bad cat? (Nameless EJ6)
Isn't the cat covered under a different warranty for 100,000 miles?
Old May 1, 2003 | 06:31 AM
ITR1071's Avatar
Default Re: Code 67 - Bad cat? (Asahi)
Yes, I have called Acura and they said it is a 8 year, 80,000 miles.
seriot
22
Apr 29, 2025 09:23 AM
jc007i
Jan 23, 2012 12:29 AM
kkwick
Apr 30, 2008 09:30 PM
Flux
Jan 29, 2005 11:22 AM
eurodeseo
Nov 13, 2004 10:49 AM
