Code 22 Check engine light!!
Old Aug 8, 2001 | 05:45 PM
JDM R98's Avatar
Default Code 22 Check engine light!!
ohk i read my code it came out to be a code 22..2 long and 2 short...if so why doesnt my speedometer work also?
Old Aug 8, 2001 | 05:54 PM
ITR 01-0907's Avatar
New User
Default Re: Code 22 Check engine light!! (JDM R98)
i posted what 22 was...here is a link to what the codes are
http://www.c-speedracing.com/faq/05.html
i have a helms book too, but i dont 'have a scanner to scan the page.
here is how to check the code...you've obviously done it, but here it is:
http://www.c-speedracing.com/faq/06.html
[Modified by ITR 01-0907, 2:58 AM 8/9/2001]
Old Aug 8, 2001 | 05:56 PM
JDM R98's Avatar
Default Re: Code 22 Check engine light!! (ITR 01-0907)
it say VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch..so that the problem..how can i fix it?and why does it make my speedometer not work?
Old Aug 8, 2001 | 06:03 PM
BUSAFREAK's Avatar
You sure you didnt by mistake unplug something and didnt notice?? Try resetting the ECU by unpluging the back up/radio fuse, wait like 20 seconds, then reinstall it and start the car..
Old Aug 8, 2001 | 06:05 PM
JDM R98's Avatar
Default Re: Code 22 Check engine light!! (ITR1162)
ohk ..let me do that again..thanks
Old Aug 8, 2001 | 06:19 PM
JDM R98's Avatar
nope..still came up..and still read 22
Old Aug 8, 2001 | 06:29 PM
sgT's Avatar
sgT
what ecu are you using?
Late model jdm motors do not have the oil pressure switch.
You will need to swap the vtec solenoid to a us model or one with the
switch on it. Your speed sensor problem is either the sensor is unplugged
or you have a wiring problem.
Old Aug 8, 2001 | 06:31 PM
BUSAFREAK's Avatar
Remove the 1P connector from the VTEC solenoid valve. With a multimeter set on ohms measure resistance between the termnal at the connector and ground. Should be between 14-30 ohms.
Old Aug 8, 2001 | 07:09 PM
JDM R98's Avatar
Default Re: Code 22 Check engine light!! (sgT)
I am using a Mugen type P28 ecu..i have a us spec solenoid,and the switch is on it..the problem which i dont know..it just keep on throwing up 22..what do you guys think it is?and how much am i lookn at to repair it at a acura dealership?and the speedsensor its the one behind the tranny right?plmk..thanks
Old Aug 8, 2001 | 10:22 PM
JDM R98's Avatar
above
Old Aug 9, 2001 | 08:15 AM
JDM R98's Avatar
anyone with know is there any wire that leads to the vtec selonoid pressure switch?beside the one in front of the engine by the intake side..plmk..thanks
36Chitownrunnin
Jun 17, 2008 08:44 PM
aleminx
Feb 18, 2006 07:25 AM
integracivic94
Aug 22, 2004 08:42 AM
Renegade
Aug 9, 2002 11:09 PM
typer_801
Mar 19, 2002 07:08 AM
