chiped
Old Apr 28, 2005 | 02:58 PM
ITR198's Avatar
Default help me out i need to find if its chiped
how would i be able to tell if my 00 itr is chiped it revs to about 8700-8800 but im not sure if it is chiped
Old Apr 28, 2005 | 03:06 PM
ZygSpeed's Avatar
Default Re: help me out i need to find if its chiped (ITR198)
1) that's about normal for an ITR (tach reads a bit high sometimes)
2) check your ECU in the passenger side footwell
Old Apr 28, 2005 | 03:17 PM
ITR198's Avatar
Default Re: help me out i need to find if its chiped (zygspeed)
thanks if its not chiped is it safe to take it that high
Old Apr 28, 2005 | 03:24 PM
ZygSpeed's Avatar
Yup, not a problem.
An ITR has stronger valve springs than a GSR and lighter intake valves to help deal with the higher revs.
When I ran a Mugen ECU a couple years ago it would rev to about 9.5K on the tach w/o any problem.
Just make sure you adjust your valves every 15K miles or so.
I just don't like bouncing or riding the limiter, but hitting it now and then is normal.
Old Apr 28, 2005 | 03:25 PM
Chris N's Avatar
It's safe to bang off the rev limiter. No, t's not recommended, but revving up there is fine. The tach reads high, so im sure you are not at an actual 8700/8800. My rev limiter, stock ecu, *looks* like 9000, but its not obviously. As the revs increase on the tach, the % error is more apparent.
Any B series revving up there is going to take on more wear and tear than usual, but that's expected.
YashiMotors
Apr 8, 2004 09:05 PM
alfaaay
Feb 10, 2004 04:12 PM
altoid
Feb 24, 2003 04:15 PM
integra-modder
Oct 27, 2002 01:44 AM
