Check engine light on only when driving
Old Apr 2, 2011 | 05:07 PM
gonein60seconds's Avatar
Default Check engine light on only when driving
Ok so it's a Jdm itr the check engine is off at idle and about 2-5 mins into driving it comes on I'm guessing it's the 02 sensor but anyone ever had this happen to them
Old Apr 2, 2011 | 06:23 PM
SlapSmak's Avatar
Default Re: Check engine light on only when driving
pull the code, come back and post it up.
Old Apr 2, 2011 | 09:30 PM
Quick99Si's Avatar
If you wanna make it a guessing game, then throw up some odds and let's get some cash involved. Otherwise, pull the code and let's discuss solutions
Old Apr 3, 2011 | 03:49 AM
Code 23 knock sensor
Old Apr 3, 2011 | 07:40 AM
Ok so I checked the code it's 23 knock sensor now it's a Jdm itr swap into an ls integra the shop used my ls harness and added vtec wires I just checked under the intake manifold and there is no connector plugged into the knock sensor and the only connector not plugged in is a grey 2 pin connector but my itr knock sensor is 1 pin was the shop sapose to take the knock sensor connector off of the itr wiring harness and add it to my ls harness
Old May 5, 2011 | 01:34 PM
ndondahows's Avatar
OK, so the 2-5 minutes thing before it throws a code is most likely how long it takes the car to warm up and then the ecu starts to actually use the engines sensors, when its cold it does not.
It is obviously a motor swap, so are you using an obd1 ecu? if so if its not a gsr or obd1 b16 ecu, the rest of the obd1 ecus do not support a knock sensor. Also, jdm motors do not have a crank fluctuation sensor (cfk) on the motor, any usdm ecu will be looking for this sensor, is it possible u misread the code?
fusedfish12
May 29, 2014 11:18 AM
9deuce9rr
May 16, 2005 08:40 PM
calgone47
Oct 6, 2004 11:46 AM
stephenB!
Mar 12, 2004 06:33 AM
