Changing Break Pads...problems...???
Old Jul 26, 2002 | 01:31 AM
Xia0w0ng's Avatar
Default Changing Break Pads...problems...???
I just changed my break pads, but for some reason, the break is softer than before...my guess is that air probably got into it (which I don't know how)....I didn't touch any break lines and stuff....
What else can it be besides air?
Old Jul 26, 2002 | 01:33 AM
nfn15037's Avatar
Default Re: Changing Break Pads...problems...??? (C-Mugen R)
BTW, its brakes Did you bleed the system after you switched pads? That is your problem if you didnt, bleed the system with some good fluid and you should be set
Old Jul 26, 2002 | 01:34 AM
Xia0w0ng's Avatar
Default Re: Changing Break Pads...problems...??? (nfn15037)
I didn't ...but i thought you don't need to bleed if you're only installing pads.
Old Jul 26, 2002 | 01:35 AM
nfn15037's Avatar
When you push the pistons back into the caliper, it can let air in. i always bleed mine whenever i change pads, and ive never had this problem.
Xia0w0ng's Avatar
guess i'll do that tomorrow
thx
[Modified by C-Mugen R, 10:36 AM 7/26/2002]
Old Jul 26, 2002 | 01:38 AM
nfn15037's Avatar
Yeah, thats all I could think of, hope you get it sorted.
Old Jul 26, 2002 | 01:39 AM
yellow blur's Avatar
sup wayne, I just changed my pads and rotors today. I bled my system today but pedal still feels a bit mushy. good luck tomorrow, I'm gonna try and bleed it again tomorrow to see if anything changes.
AUTOZONE ROTORS ROCK!
Old Jul 26, 2002 | 01:41 AM
DutchITR1689's Avatar
No, you don't have to bleed the system. If you push the piston, it will just push the fluid to the reservoir. New pads needs some time to "rub" in, to mate with the rotor. Give it some time, and don't brake too hard in the beginning...
Xia0w0ng's Avatar
Default Re: Changing Break Pads...problems...??? (yellow blur)
sup ed...
i love the n1...hee hee....
hopefully I'll get all my problmes solve by tomorrow...track event on Sat.
Old Jul 26, 2002 | 01:44 AM
sup ed...
Good to hear man, see aren't you glad that you installed them yourself...
What pads did you go with? I just went with stocks again. Good luck at the track event, I'll prob be workin or something. bleh.
Old Jul 26, 2002 | 02:01 AM
nfn15037's Avatar
Default Re: Changing Break Pads...problems...??? (DutchITR1689)
You dont HAVE to, but its a very good idea. Its gonna cost, what, $10-15 for some good fluid and 15 minutes, why not?
Old Jul 26, 2002 | 02:52 AM
Of course you can do it. But it won't solve the problem with the pads. If the pads are new, they need to rub in for max. friction. That's what everyone feels with new pads.
Old Jul 26, 2002 | 04:05 AM
DC5 Type-R's Avatar
New User
I use a set of Endless pad for track and the oem pad for daily driving. I always change it around, sometime twice in a month and never bleed it, it works fine for me
Old Jul 26, 2002 | 04:19 AM
Flux's Avatar
Default Re: Changing Break Pads...problems...??? (DC5 Type-R)
I had the same feel after changing my pads - make sure you have bedded them in properly, even then it seems to take some time for the pads to "break in". My pedal is getting firm now after a week or so..
Also, if they are high performance pads they may need some heat to get working properly...
Old Jul 26, 2002 | 04:33 AM
ILUVTEC's Avatar
Default Re: Changing Break Pads...problems...??? (Flux)
Yeah new pads always feel a little mushy once installed, they need time to break/bed in, just give it a week or so, and take it easy on them during that time, then you should be fine. Then if you think its still kinda soft, it is definately a good idea to re-bleed them, enjoy
Old Jul 26, 2002 | 04:40 AM
nEoMuGen's Avatar
Default Re: Changing Break Pads...problems...??? (ILUVTEC)
Just the pads? I installed the pads and brakes were fine on a track day. After track days I installed new brake lines, rotors and bleed the system. Now it's really really mushy. I have to push the brake pedal 1/2 way down to have the car start braking.
Old Jul 26, 2002 | 04:47 AM
Johnny Tran's Avatar
BTW, its brakes
thank you.....its a relief that spelling bothers someone besides me.
nick, who didn't major in spelling......but knows the basicz
Old Jul 26, 2002 | 04:51 AM
Dr Pooface's Avatar
Please don't spread misinformation. Air will not get in if all you are doing is pushing the pistons back.
The pads will get better in a day or two.
Old Jul 26, 2002 | 05:53 AM
nEoMuGen's Avatar
Default Re: Changing Break Pads...problems...??? (Ddub)
Agree. I change pads and clamp in pistons all the time and the brakes never feel mushy.
Old Jul 26, 2002 | 07:18 AM
BudMan's Avatar
Default Re: Changing Break Pads...problems...??? (nEoMuGen)
no need to bleed w/changing pads & doing the proper "bedding" technique according to the pad manufacturer should eliminate the immediate "mushy" feel. The bedding process does 2 things:
1) re-builds pressure in the system to move the calipers back to a "just released" position
2) allows for full contact mating of a new pad to an old rotor (matching grooves etc) - thats why some track guys will switch track rotors & track pads back to street rotors/pads....eliminate the bedding process everytime they switch pads.
Whew - I'm tired....also - getting the fluid level at max capacity will allow your brake pedal to "raise" up = meaning you won't have to push down as far to make pad contact. Check your fluid often at the track!
Natural Aspirations
Suspension & Brakes
Sep 27, 2009 03:08 PM
t0kyoStatus
Dec 28, 2008 10:34 PM
Rok_Stok
22
Oct 4, 2008 08:01 PM
CD8
Jun 10, 2002 04:34 AM
MattD@Stoptech
15
Sep 4, 2001 05:50 PM
