Camber problems
Old Apr 4, 2002 | 08:17 AM
chrisITR's Avatar
New User
Default Camber problems
I installed a set of H&R sports on my car about 7000 to 8000 miles ago and my tires are bald as all hell for the inner 2 inches of the tires. The tires themselves have 18,000 miles on them which I think is pretty good for the ones that came with the car. I'm going to have to buy some new tires soon and I wanted to go with some azenis. My problem is that if I buy a camber kit and correct the camber then am I going to have problems with the tires rubbing on the fenders? I need to figure out some way to keep from going through tires every 8000 miles.
Old Apr 4, 2002 | 08:22 AM
Willard's Avatar
Default Re: Camber problems (chrisITR)
Go to a track event and drive the car harder.
Old Apr 4, 2002 | 08:24 AM
R99's Avatar
R99
My old Potenzas had the same problem. Decent tread left to the visible eye, but when you take the tire off, it is worn bald on the inside. AND Im running stock springs.....no clue why......
Old Apr 4, 2002 | 08:31 AM
sgT's Avatar
sgT
what were the alignment readings after you lowered the car?
Old Apr 4, 2002 | 08:43 AM
reefer_bob's Avatar
Default Re: Camber problems (sgT)
That's prolly the key. Never checked the alignment after lowering the car. If you get a camber kit, you don't have to stand the wheels back perfectly straight. You can leave yourself some camber to reduce tire wear, and keep from rubbing ont he fenders.
Reefer_Bob.
Old Apr 4, 2002 | 01:10 PM
SpecR_EK's Avatar
New User
Default Re: Camber problems (reefer_bob)
Alignment is a big factor in how tires wear. When you lower a car the alignment toes out, making the inner edges wear more. Bad toe will wear a tire much faster and worse than having a bit of negative camber.
[Modified by SpecR_EK, 2:11 PM 4/4/2002]
Old Apr 4, 2002 | 01:24 PM
chrisITR's Avatar
New User
Default Re: Camber problems (SpecR_EK)
Well thanks for the info. I didn't realize that lowering will effect the toe out on the car. I think I'll go ahead and get an alignment done and see if that helps.
Old Apr 4, 2002 | 01:26 PM
sgT's Avatar
sgT
no alignment was done??
ZygSpeed's Avatar
And a fresh set of tires.
Old Apr 5, 2002 | 11:47 AM
chrisITR's Avatar
New User
Default Re: Camber problems (Zygspeed)
Well I guess I'll get the alignment done after my koni yellows get here and I get them installed. At least I only have to wait a week or so.
mikbik
13
Aug 28, 2015 03:03 AM
supermeister
Apr 28, 2009 11:13 AM
sidoe
Suspension & Brakes
10
Mar 1, 2008 06:13 AM
Understeer
Suspension & Brakes
Jun 29, 2005 05:09 AM
Rdriver
Nov 21, 2001 12:20 PM
