Bubbles in Coolant??
Old Jun 3, 2003 | 03:47 AM
CW_97_ITR's Avatar
Default Bubbles in Coolant??
Quick question...if you were to let your car warm up without the radiator cap on, when it gets all warmed up, do you get tiny bubbles coming to the surface at the open radiator cap? A tech at the local dealer said it was normal. I am wondering if there is a leak somewhere, or is it just cavitation in the pump.
Thanks for your time.
PS: new spell check rules!!
Old Jun 3, 2003 | 04:26 AM
Rory Breaker's Avatar
Default Re: Bubbles in Coolant?? (CW_97_ITR)
That is the bleeding method on newer Integras if I remember right. What year did they implement that?
Old Jun 3, 2003 | 04:32 AM
CW_97_ITR's Avatar
Default Re: Bubbles in Coolant?? (newgsrdriver)
Sorry, I should have stated that this was noticed after the system was burped for a while. These bubbles I am seeing are very tiny.
Thanks.
Old Jun 3, 2003 | 11:00 AM
Smitdog's Avatar
Very Normal, if u want to be sure that all pockets of air are out of the system then jack the front of the car up and let the car idle unitl the fans cycle twice the bleep the throttle a few times.
Next time when draining and changing coolant just jack the front of the car up and do it this way!
Old Jun 3, 2003 | 11:12 AM
ScaleExtric's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW_97_ITR &raquo;</TD></TR><TR><TD CLASS="quote">Quick question...if you were to let your car warm up without the radiator cap on, when it gets all warmed up, do you get tiny bubbles coming to the surface at the open radiator cap? A tech at the local dealer said it was normal. I am wondering if there is a leak somewhere, or is it just cavitation in the pump.
PS: new spell check rules!!</TD></TR></TABLE>usually thats a sign of a blown head gasket..Does your car overheat?
Old Jun 3, 2003 | 11:17 AM
Smitdog's Avatar
Default Re: Bubbles in Coolant?? (ScaleExtric)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScaleExtric &raquo;</TD></TR><TR><TD CLASS="quote">usually thats a sign of a blown head gasket..Does your car overheat?</TD></TR></TABLE>
Incorrect...........
Old Jun 3, 2003 | 11:22 AM
hooptie157's Avatar
I'm also with smitdog, where the hell did you here that?
4doorpowa
Jan 24, 2011 12:50 PM
S_F
15
Sep 13, 2010 01:50 PM
Tunerguy1989
Jun 15, 2010 12:16 PM
mz3bo
Feb 18, 2003 02:02 PM
